How do i make my magnaflow louder?
Bought my car with a magnaflow muffler on it
Any suggestion on how i can make it louder for now? Don't really have the money to buy new setup.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
i have two cats each cat has 2 1/2 piping going into a collector going into a 3in pipe all the way back to the muffler where would be you sugestion to put a cut out in?
never heard of anybody gutting the muffler. you'd be better off taking it out and getting a new pipe welded in it's place, same with the cats. then sell the muffler and cats and get a good bit out of them.
been very helpful, just couple more question what muffler do you recommend i get to replace the one I've got now or should i go with a true dual setup, and what is the best true dual setup?
idk if i'd have a big effect by just replacing your muffler. if you took out your cats and muffler and sold them and bought a new cat-back, you'd be rockin. as far as choosing a cat-back, you'd just have to listen to sound clips(ls1sounds.com) and go from there. i think GMMG sounds the best but its pricey. for true duals you could either get them dumped, out the back over or under the axle, h pipe or x pipe, and theres a bunch of different mufflers to choose from. i run long tube headers and 2.5'' H-pipe out the back under the axle with single chamber flowmasters. it sounds good to me and most other people like it too. before that, i had them dumped under the car and it vibrated things inside and droned a lot. the hardest thing about true duals is finding a shop that can do a good job and not half-a$$ you. good luck man.
