y-pipe bangs floor on right turns
Everyone that put motor mounts in claims it completely solved their problems, and I cant get anymore clearance out of the y-pipe.
Any other tips? Can I just Jam something inbetween the cat and the the floorboard?
should help on those pacesetters the OP has though.
http://www.thunderracing.com/catalog...mid=75&sid=528
When I had mine I put a piece of radiator hose between where it hit and put a worm clamp around it to hold it there. It worked perfect for the two years I had them. If I had it to do again I would have probably just got rid of the Y pipe and got duals. The Best V8 Stories One Small Block at Time
how does this product work?
Bold words in the quote says enough.
the mufflex bump stop was the only thing that helped it.. i modified it a little - kept it as one piece and had the rubber cushioning the arm from the floor. worked fantastic.
i think over time, the engine torque started to bend the y-pipe, but that might have been my imagination.
