magical camshaft
Old Jun 13, 2008 | 09:06 AM
wtomlinson's Avatar
Default magical camshaft
didn't know which section to put this in, because i can't tell if it's an external or internal problem.
yesterday, randomly, my car started idling like poop when i come to a stop sign, or when i'm parked, but i put it in gear. after it warms up, when i put it into gear, it's really rough like it's got a big cam in it, and it feels like it's gonna die. while driving, i can see a little bit of whitish smoke coming from the exhaust. turned it on once and something popped, and a small poof of smoke came from under the passenger wheel well, but i didn't see anything leaking.
sometimes it's hard to put it into gear, like it's really sticky. i checked trans fluid, oil, coolant, plugs, hoses, and everything's hooked up fine. please help asap because i'm leaving for pre-deployment training today and i'd like to get some kind of idea of what it is before i leave.
Old Jun 13, 2008 | 02:12 PM
wtomlinson's Avatar
also, the fans are kicking on before it's even warmed up. hasn't done that before, then again it's getting into the 100's here.
Old Jun 13, 2008 | 02:36 PM
Camaro396's Avatar
My car did that back when it was stock when I broke a vacuum line that goes into the front of the intake. Just took a new peice of hose and put it on, and problem went away. It sounded pretty cammed up though until I fixed it.
Old Jun 13, 2008 | 02:57 PM
wtomlinson's Avatar
my friend took it home and scanned it. turns out there was a misfire and the driver's side front o2 sensor is bad.
Old Jun 13, 2008 | 02:58 PM
wtomlinson's Avatar
but what would cause the "pop" and poof of smoke?
Old Jun 13, 2008 | 03:24 PM
plaf713's Avatar
bad o2, would cause the pop, probably running rich
Old Jun 13, 2008 | 05:30 PM
wtomlinson's Avatar
but it popped with smoke up front, and my exhaust is dumped over the axle.
makes sense why it would have done it, but i'm trying to figure out where the smoke came from.
Old Jun 24, 2008 | 11:25 AM
wtomlinson's Avatar
hopefully this weekend i'll be able to change out the o2 sensors and hope it's up and good. what should i check for if my trans is still sticky? like i said all fluids were good
Old Jun 24, 2008 | 12:06 PM
99NMB's Avatar
Possible blown head gasket, have you checked the coolant level?? White smoke and cooling fans coming on way early sounds like a blown head gasket to me.
Old Jun 24, 2008 | 12:30 PM
socmguy's Avatar
Restricted User
could be head gasket, time for H/C!!!
Old Jun 24, 2008 | 01:16 PM
03Sssnake's Avatar
I agree as the same thing happened to me. The car idled like it had giant cam in it, and it was apparent that there was a vacuum leak, as there was a very loud hissing noise under the hood. Turned out the PCV plumbing that goes from valve covers to the intake had a huge hole burned into it at the back of the intake manifold.
Old Jun 25, 2008 | 09:33 PM
wtomlinson's Avatar
well buddy found out that the #8 spark plug boot was a little off, so that cleared up the misfire (which i don't understand because it ran fine and it's been about a month since i changed plugs). hoping the o2 sensor will fix it up. so checking the head gasket, you gotta pull the heads i'm guessing?
Old Jun 25, 2008 | 09:54 PM
jg_98ghost's Avatar
do a pressure test on your car with all the plugs out. if a cylinder fills up with antifreeze youll know your head gasket is blown. alot easier then pulling the head. ive got a similar problem with my car and checking the head gasket with a pressure test tomorrow.
Old Jun 25, 2008 | 09:59 PM
wtomlinson's Avatar
how do you go about doing that?
Old Jun 27, 2008 | 05:01 PM
wtomlinson's Avatar
bump for knowledge on pressure testing. (search rewarded me with little info)
and a reason why the trans would be sticking so bad.
Old Jun 28, 2008 | 09:20 AM
wtomlinson's Avatar
ttt...
i am getting a day off from training so i'm gonna go get my car on a lift today. any ideas on this pressure test? or how to do one?
also what should i look for if my trans is sticking (besides fluid, i checked that)?
Old Jun 29, 2008 | 10:57 AM
ShortChevy's Avatar
This is going to be very hard to explain. They make a tester that is a clear tube that you put a special liquid in and it fits in place of your rad. cap. You then hook a vacuum pump to the tube and run the car. While pumping the vacuum pump if the liquid turns a yellowish green color from its original blue, that means you have combustion gases in your cooling system (bad head gasket, cracked head, cracked block) You can find these kits at Napa, Carquest, I'm not sure of Advance or Autozone becuase I don't go there much. Or you can do a compression test. Hopefully you can understand the garbage I just said.
