Fast 90 worth it
Old Jun 14, 2008 | 10:08 PM
Domexitium's Avatar
Default Fast 90 worth it
With all the mods i have now, would a fast 90/90 set up yield more power, if so how much?
Old Jun 14, 2008 | 10:10 PM
Pntbll309's Avatar
10-25whp depending on your car.
Old Jun 14, 2008 | 10:38 PM
Martin HD-28's Avatar
You should have an LS6 intake on there. I just installed a 92/92 combo and got an increase of about 10 HP but 0 TQ. About $120 per HP. Not worth it. But i've also got stock heads.
Old Jun 14, 2008 | 10:40 PM
MarylandSpeed's Avatar
A lot will depend on your supporting mods. On a stockish car, LS6 is great..on a cammed and greater car FAST 92 rocks.
Old Jun 15, 2008 | 11:31 AM
Red99TA's Avatar
You will definitely pick up a good bit of power considering you're already running heads/cam! Even if you have an LS6 intake now I would be you pick up at least 25RWHP.
Old Jun 15, 2008 | 11:36 AM
25? That's pushing it I think.
Old Jun 15, 2008 | 11:54 AM
ShevrolayZ28's Avatar
It's a good mod on a H/C car. I'd be getting one if I weren't planning for FI down the road.
Old Jun 15, 2008 | 01:47 PM
Red99TA's Avatar
I picked up 29RWHP going from 399 to 428 when I added a 90/90 setup with an UD pulley and tuning for the new intake. With nice heads the gains are going to be even more.
Old Jun 15, 2008 | 01:54 PM
WOW! I only picked up 10 RWHP and 0 TQ. I have UD pulley, 224/228, .581 cam, longtubes, 4.10's. I had it retuned after the 92 combo install and just picked up 10. I'm highly dissappointed. Got any pointers? Possible reasons?
Old Jun 15, 2008 | 02:17 PM
Red99TA's Avatar
You do have a smaller cam but that doesn't explain why the gains would be that much smaller. Who tuned it after the install? I should clarify that the intake was bought used and there was definitely material removed inside (not sure if it was professionally ported or someone did it at home) so I'm sure that helped over one out of the box.
