throttle body paper weight
If your intake isnt 85 (and if its a LS1/LS6 intake, its not) then you get no gains, and its so easy/cheap to make the stocker a more powerful unit,,
So say he upgrades to a FAST 90mm intake in the future. That throttle body will now no longer work because the FAST 90 uses a 4-bolt pattern, not a 3-bolt pattern.
The only other option would be to use one of the all aluminum intakes out there, and those have never proven to be worth anything over a standard LS6.
So no. He would never see the benefit of the 85mm throttle body, even in the future.
As for the idle problem...is there a hole in the blade? Also...what does the path to the IAC stepper motor look like (restricted a lot)?
https://ls1tech.com/forums/showthrea...ght=fast+85/85
