SES, poor mileage, what to do?
Old 06-23-2008, 08:36 PM
kirby's hawk's Avatar
Default SES, poor mileage, what to do?
Alright, about 3 months ago I put headers on my car. Shortly afterwards I replaced the O2 sensors. For about 2 days everything was good the the SES light came back on for the O2's and it threw these codes: P1153, P1133. These codes translate to insufficiant switching from lean to rich and rich to lean. The condition is caused by either a contamination of the o2 or an exhaust leak upstream of the sensor. I'm pretty sure there is no leak upstream but not 100% sure. I did put anticease on the threads and I am not sure if that could be causing the problem.
I'm pretty sure I need to replace them but I would really like to find the root cause first.
Has anyone had this problem before or can anyone help out.
Old 06-24-2008, 08:45 AM
Anyone.
Old 06-24-2008, 09:42 AM
bigti99a's Avatar
anticease is ok to use and i doubt it is causing this issue. check the headder bolts and make sure you are not leaking there. did you use new gaskets or reuse old ones? killing o2's that fast is always a fun way to spend $150 a pair.
Old 06-24-2008, 11:03 AM
When it first poped up I replaced the gaskets with gm ones. I'm pretty sure its not leaking at the flange but I will check the bolts to make sure there tight.
Old 06-24-2008, 11:05 AM
5301113's Avatar
Maybe your running rich. Did you get a tune?
http://gearchatter.com/viewtopic9335...4e0e6400ed4fe1
Old 06-24-2008, 11:17 AM
ZL1Killa's Avatar
just turn the codes off. there is no point in them except the computer telling you that your 02s aren't switching as much as they were when your car was stock.
turn the codes off and be happy, I have had mine off for 4 years now and my car runs fine
YOU DO NOT NEED TO REPLACE YOUR 02s!!!!!!!
just turn them off... you will get the codes again if you replace them... i had this same issue YEARS ago, bought the new corvette sensors $$$$ and they caused the error QUICKER.
trust me.
Old 06-24-2008, 12:03 PM
It has been running a little rich, and last week it got kinda bad. I could really smell it last week and all of a sudden my gas mileage went to ****. And no i havent got a tune yet.
Old 06-24-2008, 12:06 PM
trust me.
Doesnt that turn off the O2's completely? I thought you need the front ones. There has to be way fix it. I wouldnt really care about turning the codes off except my fuel mileage just got horrible.
Old 06-24-2008, 12:54 PM
AlexLs1's Avatar
I had this issue, I wasnt running any cats, I got a custom tune and after all the mods I've done since they haven't come back. You gain some power at the same time.
You can either delete the codes as previously mentioned; which works just fine
Or.
Get a custom tune, gain more power in the process.
Old 06-24-2008, 04:12 PM
King Nothing's Avatar
hmmm i've got a SES light and still get 350-360 to a tank
Old 06-24-2008, 04:49 PM
ChevyRyda99LS1's Avatar
350-360 A TANK WOW are you serious in a ls1 fbody?
Old 06-24-2008, 06:14 PM
Looks like I might just get them tuned out for now. Thanks for all the help.
Old 06-24-2008, 06:21 PM
yep with LT's, !cats! !EGR! !AIR! LS6 manifold SLP MAF K&N filter and fernco bellows i was gettin close to 400 before the LTs but i do slow take offs slow stops and just cruise on the highway
Old 06-24-2008, 08:19 PM
ZL1Killa's Avatar
TURNING OFF JUST the 1133 and 1153 codes DOES NOT TURN OFF THE 02s ENTIRELY, it just rids you of those particular codes.
please do yourself a favor and just cut them off and see where you are at after that, Also get a tune. Please trust me. I've been through it all with bolt ons and headers and yadda yadda yadda... i'm not saying i know it all, all i'm saying is i've been down that road
Old 06-25-2008, 06:05 AM
I did some searching yesterday, and it does look like that is really the best thing to do.
Old 06-25-2008, 11:27 AM
ZL1Killa's Avatar
thank you. problem solved
now you won't have to worry about running rich nor those damn codes popping up again
Old 06-26-2008, 07:33 PM
Well I wont be able to delet the code right now. But i'm wondering if my fuel filter could be part of the cause of bad mileage. I ran some seafoam through the tank and the intake. I know it is possible for the filter to clogged after a seafoam. Could the seafoam have done anything to o2's too?
Old 06-27-2008, 11:12 AM
5301113's Avatar
Yes if the seafoam did it's job and broke lose some junk you're supose to change out your fuel filter after running the seafoam in it .I think it's a full tank of gas.If you put in your oil u should change the oil after 150 miles. Try cleaning the MAF if you haven't already
Old 06-27-2008, 11:56 AM
I'm going to pick up a new filter today, and i'll grab some maf cleaner while i'm at it.
Old 06-27-2008, 12:15 PM
dailydriver's Avatar
x2
I've seen this turn off SES lights all by itself, besides giving better mileage/power/response.
Even if it is not the cause of the SES, you probably need it anyway (especially if you run an oiled aftermarket air filter), and it will NOT hurt anything!
