02 simms not working?
Old Jun 26, 2008 | 12:56 PM
defenestrate's Avatar
Default 02 simms not working?
just picked up a pair of 02 sims, and the light is still on. i even switched sides, same thing. does the code need to be cleared with an OBDII? or am i just **** out of luck? anyone?
Old Jun 26, 2008 | 01:06 PM
anyone PLEASE
Old Jun 26, 2008 | 01:16 PM
radkon's Avatar
Clear the code or just diconnect the battery for about 15 mins.
Old Jun 26, 2008 | 01:31 PM
00_transam_vert's Avatar
The computer will store the code till its cleared or after about 40 cycles (i think) it will clear.
Old Jun 26, 2008 | 02:49 PM
alright thanks a lot guys, i just cleared it anyway. gave me the p0140 and the p0160, for both sides.
Old Jun 28, 2008 | 05:37 PM
alright, light stayed off for a day now the light is back on. possible issues? i cant get my scanner on the car till tomorrow and i need to get the car through inspection on mon.
Old Jun 30, 2008 | 08:44 AM
anyone? bump
Old Jun 30, 2008 | 10:24 AM
DVS99TRANS's Avatar
I assume you just installed longtubes. If so you'll be in need of a tune for maximizing longtubes. Just get the codes deleted when you get tuned.
Old Jul 1, 2008 | 11:18 AM
well yeah i did longtubes. i took the car to get inspected yesterday and the guy gave me a pre scan and it came up saying i had cleared six codes-the car didnt have enough time to cycle through. if i get them tuned out, does it show up saying that on the computer?
Old Jul 2, 2008 | 11:05 PM
DVS99TRANS's Avatar
If you go back through and they are still in the PCM after a tune. Pull the negative on the battery for 3 hours and just let it sit. the codes will be erased from the memory in the PCM that way. You will have to put about 50-75 miles on the car before emissioned are passed ok by the PCM with this route. This allows the PCM to relearn itself. It takes about that milage maybe less for the PCM to say the AIR/EGR/O2s are good. No biggie. And that is if you show up after a tune and the codes are still being stored by the PCM. You could tell the tuner about it and will probably rid them for you. And when your tuned, resetting the PCM in this manner will not effect your tune at all if you didn't know. If some one tells you to touch the positive and negative cables to flash your PCM, cuss them out. That is not the way to discharge a capacitor, lol.
Old Jul 2, 2008 | 11:13 PM
R1ch's Avatar
Have you tried resetting the PCM? That's what I had to do for mine.
Old Jun 11, 2009 | 01:41 AM
prjctSILVERKNIGHTy2k's Avatar
im having the same problem. Picked up some sims, threw em in, cleared the code and it came back in like 20 miles. switched sides and saw no difference. I need to figure something out because im not spending the money to get it tuned until i do my cam and heads. This sucks mostly because its running so rich your eyes water and throat starts to burn if you stand behind the car too long and im getting HORRIBLE gas mileage.
Old Jun 11, 2009 | 07:41 PM
WARP211's Avatar
If I were you I would get it tuned and the get the 02's to deleted. My buddie had the same problem on his vett even after the tune until, he went back to get them deleted and now the light never comes back on. Here is your options 1 get it tune and spend the money now to get it right. or 2 wait and don't drive the car till you get cam and heads.
Old Jun 11, 2009 | 08:30 PM
Lopoetve's Avatar
So the rich smell and gas mileage doesn't give a hint?
Hint - get it tuned. those codes are 'cause it isn't running right.
Old Jun 12, 2009 | 04:34 PM
98TAjwh's Avatar
what code is it throwing? since you have o2 sims i'll assume its the "hi voltage bank 2" on both sides. your best bet is to tune out you rear o2s and be done with them.
if you're running a catless exhaust the excesive gas smell is gonna be there. bottom line is you need a tune.
Old Jun 13, 2009 | 04:31 AM
redz_02's Avatar
battery, need to clear the memory. If that doesn't do it, you may have screwed up one of your primary 02's. Wich bank is the code giving?
