Summit Racing underdrive?
Old Jul 1, 2008 | 08:38 AM
Intercooler2's Avatar
Default Summit Racing underdrive?
Anyone have one?
http://store.summitracing.com/partde...5&autoview=sku
Old Jul 1, 2008 | 08:58 AM
Redlinez's Avatar
I do, like it just fine. SFI approved as well, I don't see where you can go wrong, not to mention the price.
Old Jul 1, 2008 | 09:06 AM
Feel like you got the 10 HP gain other similar unit see? Is the finish okay or should it be powdercoated so it doesn't rust?
Old Jul 1, 2008 | 09:23 AM
00pooterSS's Avatar
It says they are clearcoated so it should not rust, I would imagine it would over time but not in the near future.
Old Jul 1, 2008 | 09:33 AM
PAGregSS's Avatar
Sweet. I hadn't seen that before. I think I'll have to buy one. Anyone using one of these with a double roller timing set? Just wondering how it clears.
Old Jul 1, 2008 | 12:40 PM
Just ordered the pulley but passed on the belt and bolt they offer.
Do I need just one belt or two? I don't trust getting belts over the Net and having them be the wrong size so does anyone know what works for this?
Anyone have the GM or other part number for a new balancer bolt and washer? Or can the stocker be reused?
Old Jul 1, 2008 | 01:13 PM
Red96TA's Avatar
Get on summit and look up crank bolt or harmonic balancer bolt. They are like 4 bucks. And yes you need a new one.
Old Jul 1, 2008 | 01:41 PM
PAGregSS's Avatar
On the product page for the pulley, there is a tab for required parts. On that tab it lists the correct OEM bolt. You cannot reuse the stock bolt.
Old Jul 1, 2008 | 02:13 PM
I asked about that bolt and it is a generic piece. Not going to chance running my motor hard with a $4.00 generic bolt that you hope they have sized right.
Old Jul 1, 2008 | 11:59 PM
05MBMLS2's Avatar
I ordered my summit balancer with the bolt and its a GM bolt they send you not a generic one.
Old Jul 2, 2008 | 02:07 AM
Their people are unreal then. The guy point blank on the phone told me it is a generic bolt.
Old Jul 2, 2008 | 09:09 AM
05MBMLS2's Avatar
Yea the 5.00 bolt that comes up in their recommended parts is an oem GM crank bolt. Some of them summit reps. probally arent too swift i guess.
Old Jul 5, 2008 | 12:02 AM
jrcws6's Avatar
I just installed the Summit UD pulley today. The install was very easy with the right tools. I am impressed with the quality of the pulley for the price. The Gatorback belts that I got with the pulley are a perfect fit. I did some driving to test everything, and there dosen't seem to be any negative side effects from it. I did notice better throttle respose. I'm going to the track Saturday to see if helps with my times.
Old Jul 5, 2008 | 01:56 AM
jetlag's Avatar
My car gained 6rwhp/10rwtq. Put the car on the dyno..got baseline runs, installed the pulley, more runs. So it was back to back testing.
Old Jul 5, 2008 | 02:16 AM
5.slow99's Avatar
anybody have a diff pulley than the summit one? lol
Old Jul 5, 2008 | 09:59 AM
Do you have the belt numbers and sizes? What tools did you use and any pointers for someone about to do it?
Pics if you have them!
Old Jul 5, 2008 | 05:32 PM
Redlinez's Avatar
25% underdrive is 25% underdrive. I haven't been to the track or anything, but my last car picked up 1 mph and dropped 1/10th consistently. The contruction of it is 2nd to none IMO>
Old Jul 5, 2008 | 05:55 PM
jrcws6's Avatar
Yeah, belt #'s are: GTR-4060763 and GTR-4040377. I used the pulley install tool from Chris (618HAWK), a must have! , a three arm puller with the smaller arms, a spare bolt (M16x2.0) I got at Home Depot to use as a base for the puller, and a torque wrench rated at 250#(rented from Pep Boys) . I also used a 2' section of exhaust pipe to put over the wrench for leverage. I did this all in my garage in about 2 1/2 hrs. The install was prettty straight forward. I broke the bolt loose from up top. Then from underneath, I switched bolts(Home Depot bolt) to use the puller The stock pulley came off easy once I had the right puller. Then I installed the UD pulley with the install tool with ease. I put the old bolt back in and torqued(240#) from up top. Then the new bolt went in at 37# and I turned the wrench about 120deg more. I made sure to put locktite on the new bolt and some RTV sealant on the keyway for the UD pulley. Every thing seem to line up just right. I did a lot of research here to find the easiest ways, and learned that the right tools would save a lot of time. I have a M6 so I put it in 5th gear and used the E brake to prevent the crank from rotating. I will have to wait until next weekend to get track results because of rain, but it definately feels quicker. I will get pics tomorrow.
Old Jul 5, 2008 | 11:33 PM
Got mine today! Here are the pics and weight. Between you and I it should be some good info.
Old Jul 5, 2008 | 11:37 PM
JayplaySS's Avatar
Moderator
I had one on my 02 SS and it was a beautiful part and worked perfect.
