New dyno #'s after Fast92 install!!
...Relax brother, you're letting opinions get you pissed. It's all good to share opinions and real life experience. Hey, if someone doesn't sway your way, don't bother getting bent. Your opinion is just as valid as others
It's all good.Ah, a buddhist in the group! Way to keep the peace!
c'mon man, it's a popular public forum, easy bro
I want to see dyno results!
It's all goodPEACE
I don't think anyone is denying that the Fast 90/92 is better than the LS6, etc. It's just a matter of what's needed for YOUR application. a complete stock cubed engine, stock bolt on's and you slap a 92mm intake on their it's gonna over do the motor.... YES it will give more hp/tq through the curve and times on the track but it's not worth the reward far as $$$ goes... for instance an LS6 may actually produce more hp/tq through the curve if the tune is right since it better suits the application. GET IT GUYS?
TOO much air intake with the 92mm for a stock application is so extreme it would probably be difficult to get the tuning parameters right compared to a simple tune with the LS6... since their's nothing to complement the 92 so tunning with the 92 you would be starting on the top and working your way down compared to the LS6 and starting on the bottom and working your way up in a sense
Now you officially got P3WED!!!
oh and on a site note... i hope your name isn't Ryan because you defintely give it a bad rep
When I stated your not using 100% of it, I meant its potential I thought it was blatantly obvious but apparently not.
As far as my other examples go. What I was stating was it would be dumb to only build a motor that my drive train can handle at the moment. You are basically saying you should do everything once all at the same time, and seeing how that IS ideal, it ain't happening unless you just came up big time! So therefore in most cases its better to bigger for future plans instead of just going on what you need now and having to do it again later. So therefore what I am saying is, if you ever plan on going to a big cam or nitrous or anything along those lines why buy an LS6 intake now, then later buy a FAST setup again? See the logic there, PLAN AHEAD!
Now if you have a problem comprehending that much let me know I will send over my little cousin to explain it to you in a simpler manner.
And as far as me starting from the bottom, like I said my motor blew so I didn't have a choice were to start. Or I would def have gone with a fast setup with direct port on stock cube hand ported at home heads. And I guarantee it would have run very well!
YOU are the exact reason why such a thread like this one will probably get locked up by the morning... and most will agree and see that when you entered with a direct name called to myself and expect NOT to get a defensive attack back at yourself you will understand the kind of person you are... there's many names for your people that quite a few old timers on this board sure probably don't have too much consideration for
Air velocity is important to an engine, you can hurt low end torque with too much intake (slower velocity). But the problem on this board is everybody is familiar with the LS1 and it is not a good engine to use as an example. Why? Because the heads/cam hell everything about this engine is very efficient and can utilize a slower velocity because it was designed to run in the higher rpms. I would venture you could increase the low end torque of an LS1 by putting a smaller longer runner intake on it at the expense of top end horsepower.
Now a better example to explain this would be to look at the L98 engine in the 3rd Gen Camaros.
They have the TPI (long tube runner) intake and the ****** would make boatloads of torque from 2000-3500 (like 350ft-lb or something crazy - stump puller), but the horsepower would die off at a measly 245hp @4,500-4,800 (i'd have to look back for exact numbers).
Now take this same L98 engine and throw a TPIS MINIRAM on it. Your low end torque will DIE, because you have essentially KILLED your air velocity and the "tuned" function of the longer runners (there was some to do with pulses with that design as well). But that Mini-Ram would make that engine scream on the topend and eat that TPI setup for lunch.
Throw a mild cam/head in it and watch it push 350hp easy.
My 2c.
we put on a fast 92-92,bmr suspension,new et streets & went 11.08 @ 121 & 1.48 60' untuned ............
now lets brake it down sum what.......
11.89 - 11.08 = 8.1 tenth faster in the 1/4 with the fast 92,et streets & bmr...so were does the credit go???????
the bmr suspension & et streets over the stock suspension & nitto are an easy comparison in 60' 1.88 - 1.48 = 4/10s of a second faster in the 1/4
so that leaves us with 4.1 tenth & 3 mph faster for the fast 92/92 setup over the ls6 intake??????????
is my thinking flawed????????
the intake showed very nice gains over the LS1 intake setup.
and i would like to see some dyno proof that the ls6 setup would come close to that on a stock h/c engine. all the results i've seen over the years seem to average out at around 8-10hp...almost 1/2 what was seen with the FAST.
and something to also consider into the equation.
albeit the FAST is $1200....but alot of us can turn right around and sell the ls6/ported TB for $400.
makes that initial investment for the FAST a bit easier to swallow
Previously made on a mustang dyno - CORRECTED
406 hp 373 tq with ls6 intake/ported tb
installed 90mm FAST intake/nick williams tb and got:
413 hp and 367 tq after tuning on same dyno as before
these are peak numbers, but under the curve the new numbers are down between 6-10 hp and 8-12 lb-ft up until 5000 rpm where the FAST setup finally eclipses the LS6 setup. I'll post a dyno graph overlay later.
My tuner told me he has seen this time and time again with FAST intakes and stock cubic inch motors. So why does everyone else on this site seem to gain 15-20 hp and 10-15 lb-ft from this swap? I just dont get it.
It didnt impress me as much as i thought it would.
