New dyno #'s after Fast92 install!!
LT headers are on my car now and it will be dyno tuned on Monday July 14. I will post the results.
My opinion, is same thing on the intake side. Put intake/tb w/ larger diameter, w/o changing the amount of air that is entering and you will reduce pressure of the charge entering the cylinder at lower engine speeds. W/O a change in timing, the car may respond worse.
At WOT, it is a different story if the old intake acted as a restriction.
I agree, with stock internals, probably not worth the investment. But why would you even consider it with no mods? Just my opinion
Just move on...he's another useless internet troll.
most of what you're saying makes sense. one thing you're not considering is a CONSTANT. as in...you must apply the same scenario to all. you can't compare a "small cam that's well setup" to a "poorly setup big cam" because we know who will win and why. compare apples to apples, man. if the same attention to detail is given to both setups, the large cam will win in every aspect except sub 1,200 rpm driving. the only reason the 224 cam is so "great" is because it is so tolerable. any joe dirtE can install this cam and it will run "good" on stock heads, etc. with MINIMAL attention.
as for the OP - congratulations on the gains found with your fast 92 install. basically you are guaranteeing yourself +20whp with almost any cam install from here on out. not to mention should you spray, you can easily install a nice direct port setup.
CHOCO open your fuggin eyes and try not to act like a 12 year old girl.
you REALLY think a 224/224 cam can out perform something like a 230/230 cam? same motor, just cam swaps... what do you think will constantly run better times
I don't think anyone is denying that the Fast 90/92 is better than the LS6, etc. It's just a matter of what's needed for YOUR application. a complete stock cubed engine, stock bolt on's and you slap a 92mm intake on their it's gonna over do the motor.... YES it will give more hp/tq through the curve and times on the track but it's not worth the reward far as $$$ goes... for instance an LS6 may actually produce more hp/tq through the curve if the tune is right since it better suits the application. GET IT GUYS?
TOO much air intake with the 92mm for a stock application is so extreme it would probably be difficult to get the tuning parameters right compared to a simple tune with the LS6... since their's nothing to complement the 92 so tunning with the 92 you would be starting on the top and working your way down compared to the LS6 and starting on the bottom and working your way up in a sense
I'm sorry some dbags feel the need to hijack a thread and spend a couple pages bitching about what's internal.
Yes we get it, the one guy was talking about rotating assembly as internal and you were talking about the entire block, heads, cam and all.
We got that on the first post. Quit being a dbag and wasting thread space waiting, trying to get the other guy to bite just so you can throw your knowlege of what internal means at him.
To the other condom breaks STFU.
The OP was nice enough to share some dyno numbers with us.
He didn't hold you at gun point and say you had to buy a fast 92 and not an LS6. He didn't say the LS6 was bad for the money.
He simply said here's what I did and here's the results I got.
Take it for what it's worth. Maybe it will help someone else.
Instead we have 4 pages of useless bickering.
You know what instead of whining go do your own tests.
Go get an LS1 instake and LS6 intake and a fast 92, hell better get a fast 90 while your at it, an SSI, and Weiand and a carb conversion intake.
Go do all that and dyno them all the same day and post it and I promise you people will still bitch you did something wrong.
Fing ungrateful, whiney little cry babies.
c'mon man, it's a popular public forum, easy bro
Relax brother, you're letting opinions get you pissed. It's all good to share opinions and real life experience. Hey, if someone doesn't sway your way, don't bother getting bent. Your opinion is just as valid as others
It's all good
