Latest design in TB porting...
Old Sep 12, 2008 | 06:35 PM
  #121
TLewis4095's Avatar
Originally Posted by FARBON CIBER
OR GOLF ***** TO MAKE THEM FLY FARTHER AND MORE ACCURATE
Originally Posted by oange ss
laminar airflow
The design on golf ***** is a great comparison, remember some designs that were outlawed in PGA? If you look at the stock TB you can imagine how it would look on a wet-flow bench. The straight side barrelling down the throat with little to deflect & disturb it. The oppisite side has a steep slope that deflects & curls the flow off it and when it hits the rest of the stream it becomes a turbulent mess. This actually does a great job of equalling it all and the slight swirl blends it with a nice clean flow exiting the TB throat into the intake manifold. That's where the power comes from. Now the improved throttle response that a good hand ported unit gives is due to removing the casting flash & sharp edges so at lower velocity it does improve the flow, but at a certain velocity it cancels out the gains that could be realized & thus produces little to no high RPM HP gains.
Old Sep 29, 2008 | 12:28 PM
  #122
trdtuner7's Avatar
Are these still available?
Old Sep 29, 2008 | 02:38 PM
  #123
LS14urStang's Avatar
How much for the bump stop mod, half shaft mod and cncing my tb?
Old Nov 12, 2008 | 07:58 AM
  #124
Judge Smales's Avatar
So does the CNC'd tb still have the improved low end throttle response like the hand ported tb's?
Old Dec 1, 2008 | 11:09 AM
  #125
jrob56's Avatar
+1 will the bump stop and half shaft add to the cost?
