Which one will net the best time reduction....
Old Jul 13, 2008 | 12:14 AM
JeaneGrae's Avatar
Default Which one will net the best time reduction....
I have a littl cash to platy with and i am stuck between getting LT's with ory....ls6 intake manifold....or a TCI 3000 stall. I Had a close run with a stock Eclipse GT and didn't like the results. what should i do next?
Old Jul 13, 2008 | 12:18 AM
ybaslo1's Avatar
Yank SS4000
02WS6_TA's Avatar
The stall will definately knock the most off of your ET's
Old Jul 13, 2008 | 12:23 AM
sixvi6-camaro's Avatar
Stall will do the most but not a TCI 3000 stall though. I'd get a higher stall than 3000 if you want to really get the car moving.
JeaneGrae's Avatar
Default .......
I still want to keep it streetable, i don't plan on a cam. The only other mods would be the lt, intake and maybe a pulley. would a 3200 be too mild if i went yank or vigilante? How much will this help me off the line?
Old Jul 13, 2008 | 12:26 AM
I'd at least get a Vig 3200 or Yank 3400. It will help a ton off the line though.. If you are worried about drivability LTs would be a better deal but will still not net as much as a good stall with sticky tires.
Old Jul 13, 2008 | 12:29 AM
JeaneGrae's Avatar
Default .....
On the avereage how much does a stall cost to install? Should i get a tranny cooler with it?
Old Jul 13, 2008 | 04:15 AM
35th SS's Avatar
guess depends where your at.get a tranny cooler/trans. temp gauge and a deep pan too.
Old Jul 13, 2008 | 06:19 AM
SOMbitch's Avatar
Search the Tranny section and you will see TCI has a history of clutch failure that takes the whole tranny out. Agreed on the stall for ET reduction and do a cooler and shift kit at the same time.
Old Jul 13, 2008 | 06:42 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Get a 3200+ converter and a trans cooler
Old Jul 13, 2008 | 10:29 AM
thislswon's Avatar
Originally Posted by JeaneGrae
I still want to keep it streetable, How much will this help me off the line?
I have a TCI 3500 SSF converter and it is perfectly fine DD, the car is my DD and my wife and her 16year old sister drive it with no problems...
With a converter/seat time/good tires you will see great improvements on ET's and 60ft's but you MPH will suffer a lil bit
I suggest not going any lower than a 3500 or there isnt much point in spending the money on a converter...as far as brands Yank and Vig are the most popular brands..i have had no issues out of my TCI in 2 years though and numerous racing/launches and DD
Definately get a Tranny Cooler and a deeper oil pan is a good idea too
Old Jul 13, 2008 | 12:31 PM
35th SS's Avatar
also do a search on torque management delete/removed on your trans.and shift extension.prolly a hit or miss works on mine.just something to think about.no shift kit here.good luck.
Old Jul 13, 2008 | 12:43 PM
MikeG's Avatar
I've got no complaints about my TCI 3500. But I'd have gone for a vig3200 if I had it to do over again.
Old Jul 13, 2008 | 01:03 PM
SSmoken's Avatar
def get atleast a 3500. Don't pay a shop to do it, its really not that difficult to do. Me and my dad did mine yesterday in our garage with just hand tools, car ramps, and a floor jack.
Old Jul 13, 2008 | 01:55 PM
01ssreda4's Avatar
3200 edge stall, really wakes the car up. you can go without a tune after the stall but i did one and its way better after the tune as far as driveability. agreed you should look into a stall with a proven rep. install it yourself if possible.
Old Jul 13, 2008 | 03:39 PM
ybaslo1's Avatar
Originally Posted by ybaslo1
Yank SS4000
Please look into my post seriously. All I did was add this converter and it dropped my e/t 1.1 seconds. Only gained 1 mph. I drive the car everywhere on nice days. I have the lock-up set at 45, anytime after that and not WOT, the car drives like a stock converter. The car drives from Chicago to Detroit often getting 27-29 mpg. Dirve it to the track 1.5 hours away, race it and drive it home. It took a little getting used to at first, but that is with a 2.73 gear. I put a 3.42 in it and it is soooooooooooo much better. With your 3.73, I bet it's not too far off from stock.
Also, I did a cooler, deep pan, and TCI flywheel at the same time. Spend the extra little money and get the yank or vig and the cooler/pan/flywheel (optional).
I have researched the **** out of this and will use my own opinion, you will not be dissapointed.
Old Jul 13, 2008 | 04:21 PM
chrs1313's Avatar
ss4000 see times in sig for proof
Old Jul 13, 2008 | 11:36 PM
5_02ls1's Avatar
x3 ss4000
Old Jul 14, 2008 | 01:46 AM
RevGTO's Avatar
Pontiacerator
I had a TCI 3000 and moved up to a Yank 3600. The difference isn't huge. The TCI was a little bit better DD, and the Yank may give more at the track (if this track will get prepped enough for me to hook) ... but the difference between stock and the 3000 was far greater than the diff btw 3000 and 3600.
Get a Transgo shift kit installed while the tranny's out for the converter change. That's a must if you want that converter to live.
Old Jul 14, 2008 | 03:07 AM
allbaugh_04's Avatar
i regret buying your ss3600. should of steered clear of ya and just got the ss4000
