MOD LS6 to fit EGR?
Old Jul 16, 2008 | 02:35 PM
disavowed10's Avatar
Default MOD LS6 to fit EGR?
thinking about just making a hole on the damn thing! has anyone everdone it?? and guides/suggestions? WILL IT WORK/PASS smog??
Old Jul 16, 2008 | 03:14 PM
2001NBMZ28's Avatar
What kind of inspection do you have? Most just delete EGR and turn the codes off. Believe SLP sells the LS6 with EGR provision, don't know if you can buy the adapter separately.
Old Jul 16, 2008 | 03:32 PM
i figure the inspector will test or look for the egr and if its missing then...
Old Jul 16, 2008 | 10:01 PM
RevGTO's Avatar
Pontiacerator
Lingenfelter Performance sells an adapter that will let the EGR tube bolt up to the manifold. You can make your EGR functional or install it just for appearance to pass visual.
Old Jul 16, 2008 | 10:59 PM
johnLs1camaro's Avatar
damn dude that sucks...im glad i dont have to deal with emissions ****...have you erased you engine codes??
Old Jul 16, 2008 | 11:04 PM
TheSilverOne's Avatar
they won't know it's missing
Old Jul 17, 2008 | 11:37 AM
bdrussell's Avatar
Not from what I am told in CA. A friend that does smog here tells me I had better get the EGR setup working on my car or it won't pass. So I need to get this done also since I have an LS6 manifold laying in my suburban.
Old Jul 17, 2008 | 02:32 PM
Jon2kZ's Avatar
I did the Lingenfelter adapter on mine, didn't want any CA smog hassles. I also cut the EGR tube flush so it doesn't hang down into the intake airflow path.
Old Jul 17, 2008 | 02:34 PM
bdrussell's Avatar
So, where did you get the adapter? It doesn't seem to show on the Lingenfelter site.
Old Jul 17, 2008 | 03:00 PM
Jon2kZ's Avatar
I'll have to look it up when I get home, here's some info.
Originally Posted by Jason Haines @ LPE
We are hoping to soon re-release our EGR adapter for the LS6 intake manifolds. Should be in a couple weeks.
http://www.lingenfelter.com/document...ctionsv1.0.pdf
Old Jul 17, 2008 | 03:02 PM
honestly you could just take the 45 minutes to switch manifolds and put your ls1 back on and safe some money
Old Jul 17, 2008 | 03:34 PM
what about the trouble codes? n wont it run a bit f'd up?
Old Jul 17, 2008 | 03:35 PM
why would it run f'd up when it was the factory one that came on the car??
Old Jul 17, 2008 | 03:36 PM
bdrussell's Avatar
Just recieved an email from a sales manager at Lingenfelter, and he said "Sorry that has been disontinued"
Oh, well, guess I will need to fab something up.
Old Jul 17, 2008 | 03:40 PM
bdrussell's Avatar
Is it really that easy to swap out the intake, maybe I am just used to the pain in an *** doing intakes on old small blocks, my 455, and those stupid 390's I have.
Old Jul 17, 2008 | 03:47 PM
its not really easy its kinda tricky getting the bolts off the back...so the first time might take you 1 to 2hours..but you get the hang of it pretty easily...ive had my manifold of probably 10 times so its a breeze now..
Old Jul 17, 2008 | 04:21 PM
180ls1's Avatar
you could just cut it off the neck of your ls1 manifold and then epoxy it to your ls6 one. Or you could try to make one out of wood. I am sure you can figure something out.
Old Jul 17, 2008 | 05:14 PM
Jon2kZ's Avatar
Try SLP?
http://www.slponline.com/view_produc...41&BIG=30041-2
Old Jul 17, 2008 | 05:47 PM
bdrussell's Avatar
Yeah, then what do I do with the LS6 intake sleeping in the back of the suburban?
Old Jul 17, 2008 | 06:31 PM
Michael02hawk's Avatar
A more expensive option would be to buy a FAST90 or 92mm intake. They are desined to work with or without EGR. Just knock out the EGR block off plates, and there ya go.
I doubt youd get any performance over the LS6 on stock cubes, but it would look good & have factory EGR for emmisions.
