another mileage thread! =P
anyway, from what i read, the things to be done are plugs, air filter, fuel filter, maf cleaning, and upping the tire pressure. i'm saving the plugs for last since that job sucks, but i changed my air filter and no change in mpg. last night i did the fuel filter and added some fuel injector cleaner.
on the maf cleaning, i actually don't even know what the maf is or how to clean it. any help here?
and the tire pressure--what is a good, safe tire pressure to deflate/inflate your tires to in order to get better mileage?
my car has roughly ~65k miles on it and is an m6, in case that wasn't already obvious. and it doesn't matter if i drive it hard or soft, always 15mpg unless i do the 1st-4th shift.
tire presure w/stock rims= 45 psi
air filter stay with paper fram, acdelco, etc
fuel filter idonno i guess there all the same
plug are a bitch so geat the best one you can afford
i always heard after you sucked up seafoam into the engine (not the oil, but through the brake booster line) that you had to change the oil after. is that true?
And do it when your neighbors arnt around lol.
