Pacesetter ORY
Old Jul 19, 2008 | 05:56 PM
firehawk#682's Avatar
Default Pacesetter ORY
Ordered some Pacesetter headers today from Texas Speed and was going to get the TSP ory but they were out of stock. Will the Pacesetter ORY work fine on my car or should I wait for the TSP? I plan on lowering the car in the future. Just wanting some input on the Pacesetter ORY. Thanks.
Old Jul 19, 2008 | 06:39 PM
95 Z28's Avatar
I've had both Y pipes. Definitely go with the Pacesetter one if you're planning on lowering your car.
Old Jul 19, 2008 | 06:51 PM
boola1341's Avatar
Pacesetter Y had no problems with ground clearance. I didn't do my motor mounts so the y bangs the floor a little under the driver side.
Old Jul 19, 2008 | 07:14 PM
ae13291's Avatar
if u do pacesetter ORY u HAVE TO get poly motor mounts! if u get TSP ory dont get lowering springs, i got pacesetter Y pipe and it has better ground clearance then my stock y pipe, but seeing how its so close to the floor board, thank god i did the motor mounts
Old Jul 19, 2008 | 07:20 PM
RotaryMuffler's Avatar
Get the pacesetter if you have ground clearance issues and get the tsp for the performance. I had a pacesetter ofr y on mine and When I did true duals I used the part of the y and found that the were the one pipe is welded to the other there is a 1 1/2in peice of steel from the tubing putting a nice block in the flow. The pacestter is a pos in my opinion.
Old Jul 20, 2008 | 12:05 AM
mycamaroSS's Avatar
you can fix the flow by dremeling the **** out of it
Old Jul 20, 2008 | 02:03 AM
ae13291's Avatar
^^^ thats what i did
Old Jul 20, 2008 | 03:50 AM
sevenstarsfall's Avatar
I have hooker headers, pacesetter ory and lm. I was amazed by the ground clearance with the ory and mine does not hit or bang the floorboard and iv got stock mounts, guess im one of the lucky ones.
I had a tsp catted y before the ory and it was kind of a pain in the *** to adjust and hung too low for my liking.
Old Jul 20, 2008 | 01:14 PM
thanks for the input, with the blockage in the pipe im assuming you just reach up the pipe and cut the part out then, and how hard is it to change the motor mounts?
Old Jul 20, 2008 | 02:37 PM
DaveX's Avatar
You can clean up the inside of the pacesetter Y with a dremmel. It takes a while but I think it's worth it. Mine does bang the floor and poly mounts should help. I have some but haven't installed them yet. They are a pain in the *** to install but if your doing headers, that is the time to do it. They aren't very expensive. The only potential downside to the poly mounts is increased vibration inside the car. But to me that would be better than the Y banging on the floor causing knock retard and loss of power, which is where I am at the moment.
