FAST idle issue
Old Aug 7, 2008 | 10:29 PM
primer84z's Avatar
Default FAST idle issue
Got my FAST 90/TPIS 90 installed, 2 issues. The throttle cable is too short even after adjusting it all the way, which I'm assuming is because the tb cam on the TPIS is way bigger than my stock 98 cam, so I dont know if you can swap the cams or I am going to have to get a throttle cable from a 01-02. Easy enough. The next issue is the idle is stuck around 1400 rpms with the cable disconnected. I tightened the idle screw some and seemed to drop it a little. It idles smooth, just high. I dont hear any whistling or anything like vacuum leaks. What can I do to trouble shoot this to find out whats wrong? Thanks.
Old Aug 7, 2008 | 11:40 PM
primer84z's Avatar
**** wheres the tech gurus? if this was a which cam/headers thread it would be 4 pages long by now...........
Old Aug 8, 2008 | 11:01 AM
primer84z's Avatar
am I the only one with a 98 and FAST intake??
Old Aug 8, 2008 | 04:30 PM
tinker-27's Avatar
i have fitted a fast 90mm tb and they stick i had to put an extra return spring on it changed to holley and sorted it !!!!
Old Aug 9, 2008 | 04:20 PM
84ls1_transam's Avatar
yeah I put an extra return spring on mine too for the same issue.
Old Aug 10, 2008 | 02:50 PM
primer84z's Avatar
check this out, today i started the car with no lid maf on, and put my finger in the IAC inlet hole on the inside of the TB, the car idled down some but was still running. The TB blade is completely closed with no cable attached and there is still air getting around it. I put my hand over the TB completely and it was about to die, so I'm pretty sure this isnt a vacuum issue, but a problem with TB. Anyone have thoughts on this?
Old Aug 10, 2008 | 07:12 PM
Your car won't run on just a vaccum leak. I would spray carb cleaner around the intake and tb. If the idle picks up you found your leak. I've never heard of a tb itself leaking.
Old Aug 10, 2008 | 07:14 PM
primer84z's Avatar
ive doused it in carb cleaner, the idle stays smooth. im going to try a new TB.
Old Aug 10, 2008 | 08:58 PM
snake charmer's Avatar
try another throttle body . some aftermarket 90mms are made for certain years .
