egr block off plate
thanks!
I was talking about the plates that bolt the Air and EGR pipes to the factory manifolds. The EGR pipe turns freely in it's plate and so I just bent up the pipe and pulled the plate off. Now I have a block off plate with a hole in it. Welding the hole in and grinding it flat finished the job before I bolted it right back on. The plates that hold the AIR pipes to the manifolds are apparently welded to the AIR systems pipes and so I just cut those pipes off and welded the holes closed on the plates.
The only reason I did all that was because I'm still running factory exhaust and there isn't a point in spending the $$ on plates when I plan to eventually get race LT headers.
Swat
