Installed LS6 manifold, tach dies
Old Aug 14, 2008 | 08:12 AM
Dave 96TA's Avatar
Default Installed LS6 manifold, tach dies
Hi all, installed an LS6 intake manifold and drove the car for the first time today. Tach comes up off the resting pin but doesn't move any higher. My Raptor shift light still works, spliced onto the green PCM wire.
Any ideas?
Old Aug 14, 2008 | 09:18 AM
Raise's Avatar
All you wires connected back? TPS and everything?
Old Aug 14, 2008 | 10:16 AM
Dave 96TA's Avatar
Yup nothing was left disconnected, if I knew I wouldn't leave it that way. Only thing I can think to do is disconnect the batt for a few minutes.
Otherwise the car runs great.
Old Aug 14, 2008 | 10:25 AM
Raise's Avatar
I dunno man. Im thinking some sort of electrical issue though. Is it revving fine?
Old Aug 14, 2008 | 10:34 AM
Dave 96TA's Avatar
Oh yeah I took it to at least 5800 because the shift light lit up.
Old Aug 14, 2008 | 01:24 PM
bczee's Avatar
Check your grounds and loose connections.. most electrical problem are grounding related.. won't hurt to check...
Old Aug 14, 2008 | 01:45 PM
toneloc60's Avatar
There are two ground wires at the back of the driver's side cylinder head. Reach back there, grab the wires and see if they're loose. Otherwise, possibly a bad connection on the wiring.
Those are my guesses.
Old Aug 14, 2008 | 01:52 PM
Raise's Avatar
Well, he wouldnt have needed to mess with those cylinder head grounds to install the manifold....and it doesnt look like the heads have been off according to the mods in his sig. I agree though, check all grounds. There are several under the hood
Old Aug 14, 2008 | 02:05 PM
Dave 96TA's Avatar
Heads have not been off (yet!). I will check the grounds after I reset the PCM.
Assuming the afternoon heat doesn't 'fix' things on the way home today.
Old Aug 14, 2008 | 02:11 PM
snake charmer's Avatar
try if you have not yet to trace the wiring on the raptor . also check the fuse relays on the inside of the car . does the tac work at all ?
Old Aug 14, 2008 | 02:19 PM
toneloc60's Avatar
Shift light was on car before the intake swap, right?
Old Aug 14, 2008 | 02:31 PM
Dave 96TA's Avatar
Correct, shift light was installed months ago.
Old Aug 14, 2008 | 04:59 PM
Dave 96TA's Avatar
When I got home I let the car run and I wiggled all the wire bundles and grounds I could reach, checked that all weatherpaks were tight, etc. Disconnected IAT/IAC/MAF/TPS and reconnected. No change.
I'm reading about people having trouble with CPS (cam pos sensor) wires. I know I plugged it back in, and it should only go one way, but maybe a pin came loose. Dammit I'm going to have to pull the intake again aren't I?
Old Aug 14, 2008 | 07:06 PM
itsjustaSB's Avatar
had the same thing happen to me check the cam sensor if u dont get the brake booster line behind it u will break the sensor off where it goes into the block when u bolt the intake down good luck
Old Aug 15, 2008 | 08:18 AM
Dave 96TA's Avatar
Ok thanks for the heads-up, I'll see what it looks like back there this weekend.
Old Aug 23, 2008 | 04:22 PM
Dave 96TA's Avatar
Fixed it. Somehow I left a connector unplugged. I swear I remember getting that specific one in. It must not have clicked and the reinstall process backed it out.
What a bear to get back there with the manifold still installed. Took 20 minutes of serious feats of flexibility, dexterity and plain old pain tolerance. Whew!
