does an ls2 intake work on ls1
Old Aug 14, 2008 | 12:59 PM
TurbopigB4C's Avatar
Default does an ls2 intake work on ls1
Will a ls2 or ls3 intake fit on a 98-99 f-body? Is it worth doing if it does?
Old Aug 14, 2008 | 01:47 PM
LS1-450's Avatar
An LS2 intake will fit with a K-Tech bolt & o-ring kit. However, you'll have to make an adapter plate for the throttle body. You'll also have to bend the fuel rail just a bit in order to line up the bolt holes for mounting. Further, the LS2 intake must be ported in order to see improvements. Go with at least an 85mm TB if you do it.
Old Aug 14, 2008 | 02:15 PM
snake charmer's Avatar
the ls2 intakes have 90mm throttle bodies . it will bolt on to the heads but the injectors on it are different . ktech does make a kit to help with the marriage of the ls2 intake on our rides . might think about go ahead and getting some new aftermarket fuel rails .
Old Aug 14, 2008 | 05:32 PM
jetlag's Avatar
Buy an LS6 intake.
Old Aug 14, 2008 | 06:24 PM
teke184's Avatar
didn't GMHP test the ls2 intake on an cammed ls1 years ago when the ls2 came out.
found out it LOST power!!
why go through all the trouble when an ls6 is proven, and the FAST is proven better than that.
Old Aug 14, 2008 | 06:28 PM
BIG BAD BLACKSS's Avatar
Originally Posted by jetlag
Buy an LS6 intake.
Old Aug 15, 2008 | 08:43 AM
TLewis4095's Avatar
You are right on.
Due to the sonic, or vibration weld process used the LS2 intake leaks badly between runners so even though it out flows the LS6, the LS6 makes more power.
Old Aug 15, 2008 | 07:24 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
LS6 for sure.
Old Aug 15, 2008 | 07:46 PM
Johnnystock's Avatar
Originally Posted by TLewis4095
You are right on.
I didnt know that!!
OP get the LS6..
Old Aug 15, 2008 | 08:49 PM
LS1-450's Avatar
Back to answering your question; Go into the dyno section & find the numbers generated from PORTED LS2 intakes. I have personally installed an LS2 intake on my LS1engine & it can be installed as was described. The tested LS2 intake that lost power was not ported. This discussion has been beat to death years ago & a search will reveal the information.
Old Aug 15, 2008 | 11:34 PM
NemeSS's Avatar
just get the dam ls6, bolts right in, makes more power, less hassle, reuse stock tb,fuel rail, injectors
makes more power
Old Aug 16, 2008 | 10:18 AM
TLewis4095's Avatar
And although porting the LS2 will make power over a non ported LS2, it weakens the runner walls even more and thus results in more leakage.
