Please help!
Old Sep 1, 2008 | 04:15 PM
camaroman98's Avatar
Default Please help!
Hello. I own a 98 camaro Z28. I have had it for about 7 years. I can't get the car to start. I replaced the battery, oil pump, starter and alternator. I orignally took it to a mechanic becasue it was'nt holding oil pressure. So, he stripped the motor down, built it back up. I drove it about 10 miles home. nothing wrong seemed to go on. I then got in the garage started it, and it cranked just fine. I then put it into gear, it cut off. I can not get it to turn back over. battery gague reads enough juice. I am confused. The car is just sitting there in my garage and it is killing me. Any help would be greatly appreciated.
Old Sep 1, 2008 | 04:30 PM
hey man
Old Sep 2, 2008 | 08:10 PM
theblur98ss's Avatar
Does it turn over at all? Maybe check all the grounds and battery connections if not.
Old Sep 6, 2008 | 10:14 PM
Hey. Thanks for replying. No it doesn't turn over at all. I checked all of the connections. Everything seems to be in working order. Would trips me up is that it ran at idle for 15 minutes, then when i put it in gear, it cut off. Thanks for the suggestion. Any more would be helpful.
Old Sep 6, 2008 | 10:18 PM
conan's Avatar
A4 or M6 trans? the reason i ask is that if its a m6 could be the clutch switch. if a auto have you tried putting the shifter in N?? Also do any of your gauges work? lights?
Old Sep 7, 2008 | 07:31 PM
Hello. It is an automatic. I tired putting it into neutral...no luck. No, my spedo doesn't work or my tack.battery gauge seems to be fine
Old Sep 7, 2008 | 07:37 PM
MrElectric03's Avatar
Have you checked to obvious? Fuses? Grounds?
Do you know if the motor was pulled or if he just took the front cover off?Do you know what was done to it?
Old Sep 7, 2008 | 09:18 PM
jrocstar's Avatar
ignition switch i am sezin. but that is a internet diagnosis. my fix would be to take it back to that guy and have him fix that also.
