fuel injectors
Old Sep 10, 2008 | 01:43 PM
TOTHEDARKSIDE's Avatar
Default fuel injectors
Does a stock 1999 ls1 camaro need high or low impedence injectors?
Old Sep 10, 2008 | 02:05 PM
Robert@G-Force's Avatar
it uses high impedence injectors
Old Sep 10, 2008 | 02:06 PM
is there a way to run low impedence?
Old Sep 10, 2008 | 02:24 PM
not with your factory PCM you would need a low impedence driver
Old Sep 10, 2008 | 02:32 PM
BlackScreaminMachine's Avatar
Internet Mechanic
That is correct.
I gues the bigger question is why do you need them.
My bud just got his car retuned, running on a stock pump and stock injectors for a 2002, used to make 420 rwhp cam only before a 12 bolt, went to 380's and was retuned today to about mid 390 @ a 86% duty cycle.
Old Sep 10, 2008 | 02:48 PM
we are currently rebuilding the engine and going with 59cc heads and ms4 cam and i have some 55# injectors but they are low impedence. What is the Driver that you are talking about?
Old Sep 11, 2008 | 08:23 AM
Ok i sold the 55# low imp. injectors now i need to buy some high imp. What size should i buy for h/c/i. Car also has a nx maf wet kit.
Old Sep 11, 2008 | 11:00 AM
Internet Mechanic
#42 Green tops max, no need for more, the Wet Kit will supply its own fuel, get a decent pump such as a Racetronix 255lph w/ hotwire
