Pulling my Motor
Old Sep 19, 2008 | 08:23 PM
philsblwnz28's Avatar
Default Pulling my Motor
Ok, I am pulling the motor on my 98 z28. I need to know if there is any ground wires or bolts on the back of the heads? I am down to pulling the motor mount bolts and the torque conv. bolts and she should come out.....Let me know where all the ground straps might be please.....Thanks
Old Sep 19, 2008 | 08:29 PM
madd maxx's Avatar
are you pulling the motor or are you dropping the motor for that vehicle needs to come out of the bottom of it.
Old Sep 19, 2008 | 09:27 PM
t/a98's Avatar
there might be more but on the passenger side your transmission dipstick tube is bolted to that head and theres like, one bolt on the drivers side with ground wires, thats all i remember and i just did it to my 98 a4 you can get it out of the top pretty easy, the worst part was unbolting the dipstick from the back of the head as it ended up pulling out of the transmission and spilling fluild everywhere....
Old Sep 19, 2008 | 09:45 PM
conan's Avatar
There are at least 3 grounds on the back of the heads driver side for sure and i think there is one on the pass side.
Old Sep 19, 2008 | 10:00 PM
t/a98's Avatar
haha yea what he said, i had my heads off so quick i didnt really pay attention to how many but im sure hes right
Old Sep 20, 2008 | 04:22 AM
I am pulling the motor out the top........Why isnt my oil dipstick tube coming out? I unbolted it from the side of the head......Thanks for the help
Old Sep 20, 2008 | 08:11 AM
conan's Avatar
Twist it in the block hole there is a O ring on the bottom of the dip stick tube.
Old Sep 20, 2008 | 04:48 PM
okay will go try now and get back....thanks
Old Sep 22, 2008 | 12:36 AM
camaroguy26's Avatar
yeah the dipstick takes some finangling around to get it out but it comes out. Only one bolt holds it in. As for the grounds there's 3 on one side and one on the other, but there's only one bolt on each head for them all. If you are pulling the harness with the engine you don't need to pull them though I believe. Pretty sure they run with the wiring harness. and ground elsewhere, but not sure where?
