duals or y?
Old Sep 20, 2008 | 04:07 PM
camaroracer91's Avatar
Default duals or y?
which would you guys do for a dd? A catted y from tsp or true duals, the only problem with the catted y is that i have a stock cb with a flowmaster muffler only. Any input would help
Old Sep 20, 2008 | 04:14 PM
ndfrsd6's Avatar
i partial to the true duals .....
Old Sep 20, 2008 | 04:38 PM
how much will it coast me to run it out the back and not dump it
Old Sep 20, 2008 | 04:46 PM
ndfrsd6's Avatar
you have to call your speed shop that will do it....my setup was about 600 ish it is a little more expensive though
Old Sep 20, 2008 | 07:47 PM
blown03mustang's Avatar
the average muffler shop around my area said 400ish to run out the back, 200 to dump!
Old Sep 20, 2008 | 07:51 PM
SuperSlow02's Avatar
Catted Y with a cut out is my preference
Old Sep 20, 2008 | 08:20 PM
same here, wish i had just went with my gut when i bought my car but hey, u live and learn
Old Sep 20, 2008 | 10:41 PM
the only problem again with the catted y is that i have a stock cat back holding back power and i figure its cheaper to just run it out the back then buy a whole new catback right?
Old Sep 21, 2008 | 08:42 AM
i think ud be better off runnin duals all the way back, it "should" be a lil cheaper and sound a lil better as well. if ur dead set on flows then have the shop run the pipes through some flows and out the back, problem solved
Old Sep 21, 2008 | 09:13 AM
SimRacer1's Avatar
isnt that what the cutout is for? cutout closed for better emissions and lower sound, cutout open when you need those extra 20 horses or so.
Old Sep 21, 2008 | 09:38 AM
yea but u dont want to ride around with ur cutout open all the time.....plus it sounds cleaner with a good muffler/s
Old Sep 21, 2008 | 01:05 PM
Vndcatr's Avatar
So...Are you asking us what we think you should get ? Or which one is better to get ..?
True duals ofcourse flows better and when you start adding up the mods including a cam. You will be very happy you went the TD route.
Y pipe has little better clearance depending on suspension, Restrict flow depending on size and brand. But thats where a cutout comes in handy.
If your worried about emissions or sound or looks of it .. just get a Y .. problem solved
Old Sep 21, 2008 | 03:14 PM
im saying it more on the lines of is it more worth it just to run duals put the back rather than buying a new cb
Old Sep 21, 2008 | 06:14 PM
all my friends that went true duals hate them after a year. Dosnt mean you will or others will, but some cant stand the noise after awhile of driving it all the time. Thats why I suggested the Catted Y with a cutout. Alot of people say the cats really clean up the sound of our cars. And with an Electric Cut out in there you can go open at the push of a button.
Old Sep 21, 2008 | 07:13 PM
thunderstruck507's Avatar
true duals are about the only way to get a ls1 sounding good anyway, so do that
just because they're duals doesn't mean that haveto be loud if thats not what you want
Old Sep 21, 2008 | 07:14 PM
i3oosted's Avatar
Y w/ electronic cut out
Old Sep 21, 2008 | 07:17 PM
brandotron's Avatar
True duals are mas 'spensives for a DD. I would probably go with the catted Y and a cheap catback system. I have the Hooker catback on my ride and it aint bad. You can find it for like $350. If you need more aggressive, do a cutout.
Old Sep 21, 2008 | 07:25 PM
this might be a dumb question but i already have high flow cats can i get a ory and put the cats i already have on or would it be easier to just buy a catted y.
Old Sep 21, 2008 | 07:27 PM
brandotron's Avatar
It is possible, but of course you'd have to get your cats welded into the new Y. Check your prices and see if it's worth it. You could always sell the Hi Flow cats you have now...though the stock cats aren't that restrictive...
Old Sep 21, 2008 | 07:39 PM
well its 200 more for the catted y
