Soldier in Iraq needs help
Old Sep 22, 2008 | 08:27 AM
Sling13's Avatar
Default Soldier in Iraq needs help
Hey I am currently deployed to Iraq and I am looking at an 01' camaro from a user on here his name is zmonsterjb and the installed a built lq9 shortblock with what seems to be an ls6 top end,
I am a blackhawk machanic so I dont know to much about cars that why I am posting this thread after doing a lot of research i was very interested in the car but as of late I seen something that bothers me on the valve cover he has wrapped the breather with a red shop towel he said it was to stop the mist from the crank case pressure? Well im just not sure if this is normal i am looking for a daily driver type of car like a toy and I am just not sure how reliable the car whould be?
Can anyone out there help me out and give a little input on what i can do thanks a lot
Here is the link to the post https://ls1tech.com/forums/showth...489&highlight=
Old Sep 22, 2008 | 04:39 PM
Pwebbz28's Avatar
He is venting the crankcase pressure to the atmosphere. Not a problem but you will have a VERY dirty engine bay. The rag is normal to try and combat the oil mist.
The link didnt work.
Old Sep 23, 2008 | 03:38 AM
Sling13's Avatar
ttttt
Old Sep 23, 2008 | 04:22 AM
99blancoSS's Avatar
I look at it this way. The best he could do to vent the crankcase pressure is to use a rag??!?!? What other stuff is then hacked?? Thats a red flag on that setup if you ask me. DO yourself a favor and look elsewhere. The simplest thing to do he could only manage a rag... What do you think happened when something complicated came up? How did he fix that?
Woud you use a rag on a blackhawk?? to prevent oil mist when a simple oil cap filter can be had for cheap ??? OR even better a catch can setup ?? We're not talking rocket science here. Stear clear IMO, thats a complete a hack job way to deal with it.
what else has been hacked? You see my point.
Old Sep 23, 2008 | 10:33 PM
zmonsterjb's Avatar
Blanco your way off or confused in what he was trying to explain.
This is a pic of the car.
The rag is wrapped around the "smiple oil cap filter" to prevent mist from hitting the engine bay
There is nothing "Hack" about this car!
Jason you can also see by what he explained, is exactly what I said in a pm I sent you earlier.
Old Sep 23, 2008 | 10:44 PM
99blancoSS's Avatar
Ahhh,...LOL thats not what I had pictured in my mind.....
Ok, yep looks good,controlling the mist with it. The link wasnt working when I tried to look at it. I pictured a hose off the valve cover with a rag wrapped around it.. LMAO!!
Nice looking engine bay!
Old Sep 23, 2008 | 10:57 PM
zmonsterjb's Avatar
thanks bud! I kind of figured that!
Old Oct 9, 2008 | 12:44 AM
the big kahuna's Avatar
I would ask to do a leak down test you should not see mist or smoke wile it is running . could have bad rings
Old Oct 9, 2008 | 01:38 AM
lubsvitek's Avatar
Whats the rag by the PCM for? You venting codes?
Old Oct 9, 2008 | 08:12 AM
tillery's Avatar
Its aprefiilter also, You can go with a catchcan setup to do the same thing. No need in puting in back into the engine via the pcv system. I used to work on blackhawks,apaches and chinooks. You would believe the crap some people try to pull as maintaince.
Old Oct 10, 2008 | 12:53 PM
zmonsterjb's Avatar
big kahuna your lost!
Yes the rag by the pcm/ecu is thier to vent codes!
What does working on blackhawks have to do with this? Does it make a difference that I fly blackhawks?
Old Oct 10, 2008 | 03:43 PM
tillery's Avatar
Not really, I know alot of pilots who cant tell a wrench from an engine. Or not to leave any of thier crap on the flight deck. Exspecialy right on the pirimary flight controls. Or here is a funny one you might like, When friction is on, Flight control is hard to move. I had some guys before I went into my last unit coudnt figure why the Helo would not defuel,Had the ESSS hooked up. And to save a rig pin, they disconnected the servos from at the swash plate under hyd press! Ever seen a swash plate lift and slam down on a transmission?
Old Oct 10, 2008 | 03:47 PM
tillery's Avatar
The OP stated he is an aviator. Just some common ground. Ive got lots of experiane on many helos. And NASA proved a monkey can pilot, but you wont see one carrying a toolbox.
