ARP Header Bolts
Old Sep 22, 2008 | 05:25 PM
black02m6ws6's Avatar
Default ARP Header Bolts
Hey,
I'm installing Longtubes this weekend and want to get some ARP Header Bolts. Only question is should i get the 3/4" or the 1" length. 3/4" are only $18 while the 1" are $34? Thanks
Old Sep 22, 2008 | 06:18 PM
tee-boy's Avatar
I would just reuse the stock bolts. Those bolts aren't exactly bearing much load.
Old Sep 22, 2008 | 06:19 PM
conan's Avatar
I would go with the 1''.
Old Sep 22, 2008 | 06:30 PM
Thanks, I was going to reuse old ones but there rusty and for a couple bucks i'd rather have nice shiny ones. I'll go 1".
Old Sep 22, 2008 | 06:41 PM
conan's Avatar
Thats why I replaced mine... only i spent $100 on the studs. They look bad *** though. If you have the option check to see if they come in 12pt heads. I love the way the 12pt nuts with look with the studs.
Also put alittle hi temp antiseze on the bolt threads when reinstalling. If you haven't changed your spark plugs and wires reciently now would be the best time to do it.
Old Sep 22, 2008 | 09:47 PM
Yea, i'm getting the 12 pt heads, I love the way they look also! Yep, im doing the plugs and wires also. Thanks for the help.
Old Sep 22, 2008 | 10:59 PM
MrElectric03's Avatar
The required length is 1" IIRC, but I bought my SS locking bolts for $40, much better than just regular bolts for $34.
Old Sep 23, 2008 | 01:11 PM
JScamaro's Avatar
I went with studs becasue it makes it so easy to install and remove the headers.
Old Sep 23, 2008 | 02:11 PM
SS1875's Avatar
Same here....very convenient.
