X-pipe folks please chime in...
If you are buying...where?
If it's a custom..any pics?
I was going with an "H" config. but after all the hype on the "X" setup I guess I'll go with the "X"...
Thanks much!!!
Ron
I think I'm just going to flange on both ends though.
FYI to help hang the mufflers, remove the rear seat bolts that stick out at the bottom near the end of the car (above the mufflers).. and go to the hardware store and get one about an inch longer, you can put that bolt in place of the stocker, and use the hanger on the extended bolt length with a nut on the end.
Got the kit from them. Only needed the two modifications mentioned above to make it work. I also ordered my mandrel bent turndowns from Dr Gas. I run TR LTs on my car
check this out
http://www.badrap.net/members/Devil505/Exhaust/
and some not so good pics at
http://home.tampabay.rr.com/mk/true_dual_exhaust.htm
The 2nd link is my car (sorry about my shitty camera) but they first link was done by the same guy that did mine and they are very similar.
$215 for the dr gas kit shipped.
$100 for a set of sprial flows.
$100 for an exhaust shop to weld and install and hang.
comes out to $415. Now if you do the welding/install yourself its even cheaper. Only real snag you have is lining up the driver side header.
did you guys loose any low-end with a complete 3" true duals setup?
And - I've never seen a 3" X system of any kind not pick up a good amount of torque - and power all across the power band.
