Anyone Found Trouble Descreening the MAF?
Old 10-02-2008, 09:20 AM
bczee's Avatar
IMO, if your a DD or mostly driven on the street/highway.. I would leave the screens in place.. if your going for MAX HP at High RPM.. you might gain a few by de-screening.
At the Higher RPM range, the speed of the air flow would not be very accurate anyway at WOT. For low and mid range RPM, the screen does help keep the air flow straight and give the MAF Wire a better and accurate reading.
Old 10-02-2008, 09:42 AM
Predator's Avatar
That's a good way of putting it. I wish I thought of it.
Old 10-02-2008, 09:59 AM
78novacaine's Avatar
mine get messed up when i was removin the maf from the stock lid (bitch was on there tight as hell) so i went ahead and removed it completely, no problems, but no real gains either
Old 10-02-2008, 10:19 AM
colews6's Avatar
leave the front screnn in to straighten the air flow and to keep debris out and remove the end screen. seperate both ends, polish the insides of the housing. i did that to mine and notice a good throttle response.
Old 10-02-2008, 10:55 AM
TORCHD 02 TA's Avatar
people that have pine needles, leaves, cats, birds or dogs coming thru getting onto your MAF you have other serious issues that you need to tend to
Old 10-02-2008, 10:56 AM
Race your car!
JL ws-6's Avatar
I can say, that there's one thing I have learned about these cars. Messing with the MAF is gonna give you more headaches then you'll ever see in power returns.
Leave the thing alone, if you're at the point that you're making 800 rwhp and it's a restriction then you need to tune the car in SD/open loop and ditch the maf, o2 sensors and all that crap because at that power level they don't work right.
Leave the stock maf alone, don't waste your time with that 85mm slp one they are junk and fail more often then not, and all the other aftermarket supposed magic maf's are also a waste.
I've been 9.5 @ 142 mph, with a stock screened MAF on my car. I'm gonna be hard pressed to believe anyone that's gonna tell me that they don't work, and that it's a massive power robbing restriction. Put it this way, I'm pretty sure that if I change to something else, I don't in the most remote way expect the car to go from 9.5 @ 142 to 9.3 @ 145 or anything like that, hell I bet it wouldn't even pick up a tenth or a mph.
Old 10-02-2008, 11:05 AM
I guess no one saw this in my earlier post
Just an FYI guys, ALL 85mm MAF that corvettes have fromt he factory have NO SCREEN
Old 10-02-2008, 04:13 PM
TheBlueKnight's Avatar
Thaks for all the advice, I'm just gonna leave it on!
2000 WS.6 K&N Filter/ Magnaflow CB
Old 10-02-2008, 04:50 PM
highway21's Avatar
on my m6 it worked just fine....pulled it out in one piece
Old 10-02-2008, 06:11 PM
69LT1Bird's Avatar
I have tested mine screened and de-screened. When you monitor the MAF frequency in the HP Tuner scanner, the frequency reading is erratic and bounces with the screen removed and is more stable with the screen installed at WOT. I did not see any performace gain either perceived or in actual lb/min of air flow improvement with the screen removed.
To say you actually have improved throttle response is hard to believe or explain but if the car was tuned after the install that could explain it.
Old 10-03-2008, 11:09 AM
corvet786c's Avatar
I've ported and removed MAF screens on 3 LS1 fbodies within the last 8 years. 2 autos and 1 m6. Never had a problem. All those cars ran normal or better too.
