Just installed Solid Motor Mounts, questions regarding Trans...
Old Oct 7, 2008 | 09:52 PM
Monello's Avatar
Default Just installed Solid Motor Mounts, questions regarding Trans...
Can I leave the stock mount on there?
Its an A4
Old Oct 7, 2008 | 09:55 PM
TheSilverOne's Avatar
yes, I did
Old Oct 7, 2008 | 10:03 PM
*98TransAm*'s Avatar
might as well upgrade it, doesnt cost to much but if your not having any vibrations you could probably leave it.
Old Oct 7, 2008 | 10:19 PM
Monello's Avatar
I want the least vibrations. Only reason I am installing solid mounts because the factory ones were melting.
Old Oct 7, 2008 | 10:26 PM
TORCHD 02 TA's Avatar
soild mounts yikes... Why did not go with poly mounts? Just wondering?
Old Oct 7, 2008 | 10:29 PM
Monello's Avatar
because they will melt.
Old Oct 7, 2008 | 10:34 PM
LS184's Avatar
after market poly ones? ive never seen them melt
Old Oct 7, 2008 | 10:37 PM
Monello's Avatar
I have the PTK turbo kit. The crossover pipe runs next to it, the header is directly above it, and the downpipe is on the other side of it.
Old Oct 7, 2008 | 10:39 PM
ahhhhhhhhhhhhhhhhhhhh now it makes sense
Old Oct 7, 2008 | 10:41 PM
LS184's Avatar
o lol
Old Oct 7, 2008 | 10:42 PM
novaflash2002's Avatar
those solid mount are hard on the k-member. you have a lote of energy that has to go somewhere, so sometimes that turns into a crack. had it happen many times in a nova. not recomended for street use.
Old Oct 8, 2008 | 09:20 AM
thats comparing apples to oranges
Old Oct 8, 2008 | 03:09 PM
WYATT318MOPAR's Avatar
I would go poly on the trany else it will probably pull apart later on....could be a while though
Old Oct 8, 2008 | 04:14 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've go the solid motor mounts and a poly trans mount. Haven't had any problems yet
Old Oct 10, 2008 | 10:27 PM
when it is a after market k-member is apples to apples.
Old Oct 10, 2008 | 10:39 PM
not all aftermarket parts are made to the same build quality
Old Oct 13, 2008 | 07:15 AM
BIG_MIKE2005's Avatar
Exactly. I haven't heard of a sinlge cracked k-member in a 98-02 f-body b/c of solid motor mounts.
Old Oct 13, 2008 | 07:26 PM
if you read what i said, i said sometimes they can crack. what i dont understand is that and aftermarket k-member in a nova are made to put a big-block in them. if you put a supercharger on that it adds alote of stress, so why would it be less quality?
