The LS1 "Grand-Am Cup" camshaft > This is a MONSTER!
#81
There has got to be someone that has run this cam on a stock cubic inch motor. Someone please reply with some feed back hopefully dyno numbers and/or track times.
#82
cammin beasst, let us know when you get that thing in! i want to hear it running. i only live 3mi form gmmg and rp motorsports. thanks , jeff <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
#83
Hey Cammin BeaSSt how's this project comming along
i can't wait to hear that cam <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
#84
Anyone??????????????????????? <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
#88
We just pulled a car off the dyno with this cam. Its a race car, and Im not sure if he wants his numbers to be made public. Stout? To say the least! It was just a bolton package- CNC LS6 heads, and the 239/251 cam ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Give Lou at LG a call, and he may release them![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Louis
Louis
#89
Louis
Louis
#92
Originally posted by Cammin BeaSSt:
Anyone wanna put down guesses as to what she will make?? I dont plan on keeping this setup for long, just being the demo for the rest of you guys so to speakcan you send some of that money my way, if you got some much of it to throw around
#95
The car in question is a World Challenge race car. It was on it's
way back from the Sebring race, where he broke the diff on the standing
start. He showed up with the old ASA cam (525 lift), and had only
399rwhp . Needless to say, he left happy.
We used our own LS1 edit program. It idles at 1400, with no problem,
if it was for the street, we could have worked on the idle to get it
to about 1100.
The engine that we worked on, had 2 seasons of world challenge racing
on it already. The owner was on a budget, so we could only get
11.1 compression. The engine had to be built to the rules of that
class, and they require the GM c&c'd heads with NO modifications at all.
The TB also had to be stock, and it did not have an underdrive pulley.
The dyno runs were done on his 335/35x18 tires, and he had a cold
air intake that was just above the radiator, so until he hits some high
speed, it will suck some hot air off the radiator.
Having said that, the car did 450.7rwhp/ 402rwtq with peak power at 6700
We could have raised the hp and the rev limit if he had a bigger $$budget
but we put the cam in straight up at 106 intake center. We feel that to
be competitive, we will need to get in the 470+ rwhp range, and still stay
within the rules.
We are going to build a World Challenge C5 this summer, and we will
be building our own engine for it. The rules are very restrictive, and
they tear the engines apart if you are in the top 5, or if you get picked
out of a hat. They weigh the crank, rods and pistons, Check Port volume,
check Compression, valve size and bore and stroke.
Before the race, they pump and whistle the engine for Cu In and Comp
Ratio without taking the engine apart, then the tear down after the race.
It keeps everyone honest.
Later,
Lou Gigliotti LGM
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
to about 1100.
within the rules.
Later,
Lou Gigliotti LGM
#97
Originally Posted by binksz06
Thanks for all the information Lou.
Looks like an excellent street cam to me. ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Cal - you were right
joel
#98
Here's the old thread on the Grand Am cam with Lou and Louis' info/Dyno.
alot of work. It does make me grin.
joel
joel
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#100
Originally Posted by LS1derfull
Thanks Joel, this is the info i was looking for. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Actually, you gave me some good advice, on RPMs and stock bottom end, when I initially looked into this setup.
joel
