are heads worth it?
Old Sep 13, 2003 | 09:34 PM
Stone0fFire's Avatar
Default are heads worth it?
if i have all bolt ons and a G5X2, how much would stage 2 LS6 heads help the cause?
what about stage 2 LS1 heads?
trying to decide if it is worth it or not
Old Sep 13, 2003 | 09:52 PM
blk~2000~Z28's Avatar
Default Re: are heads worth it?
I would say absolutely yes they are. The only way to take full advantage of them though would be another tune with that cam to dial them in correctly. If you have the money then get some heads, plenty of people in here can show you their dyno graphs as to why heads are worth it.
Old Sep 13, 2003 | 10:25 PM
Visceral's Avatar
That depends on alot of things
What is ~$2000 plus installation worth to you?
What is 35 rwhp worth to you?
How much more annoying would valvetrain noise be if it got worse?
Are there other things that you will need to upgrade because you will have more power? (12 bolt rear, LS1 tuning, PCV issues....etc,etc.)
I think only you can decide if its all worth "it" to you.
chris
Old Sep 14, 2003 | 09:39 PM
35hp for $2000 sounds like the worst bang for the buck ever. id rather get some nitrous.
Old Sep 14, 2003 | 10:21 PM
post #1
post #2
post #3
The first two posts are fine examples of the extreme potential of that cam when mated with a set of heads. The third post is an excellent example of what to expect with that cam with no heads. So I am going to say again heads are definently worth it since you have that cam. That cam just seems to REALLY like a freer flowing set of heads. Yeah $2000 dollars is steep but I do not think you would regret spending it after putting down some monster numbers like those.
Old Sep 14, 2003 | 10:37 PM
offaxis's Avatar
I would check out the posts above and also call LG and see whos heads he recomends. I think the right set of heads make the combo. A good set of heads are worth 40 or so HP .
Good luck with the combo
Old Sep 15, 2003 | 12:44 AM
jrp's Avatar
jrp
SN95 Director
for my application heads arent worth it to me. im content with bolt ons and cam
i like the hp gains and all but then i remember strict emissions laws and 2.30 gallon gas prices and it brings me back to reality :p
Old Sep 15, 2003 | 10:18 AM
robertbartsch's Avatar
...my ported ls6 heads INCREASED my gas mileage....this was a result on increased compression (10.1 vs. 11.4)
you also get rid of that annoying exhuast rasp...
Old Sep 15, 2003 | 01:30 PM
pdd's Avatar
pdd
Old Sep 15, 2003 | 03:17 PM
Viper's Avatar
"...my ported ls6 heads INCREASED my gas mileage....this was a result on increased compression (10.1 vs. 11.4)
you also get rid of that annoying exhuast rasp... "
Right on!! My car did the same with H/C.
Old Sep 15, 2003 | 05:02 PM
jmX's Avatar
jmX
Another thing to consider is that you can't use milled heads with that big cam, unless you flycut your pistons. If your pistons are already flycut, then slap heads on there and have fun.
