ring land or head gasket symptom????
Then ran it up to 120mph on a 150 shot. and the smoke kept pouring out the back.
at idle it smokes noticable but with a little rev it looks like a bug fogger. It makes no noise and is not building pressure in the cooling system
I hope it is just a head gasket.
the smoke don't smell like oil and i only have water in it(no antifreeze at all)
so i don't know unless mobil 1 dosn't have the smell of regular oil
just wondering what you guys think it is . and should i drive it home the 3 mile's or have it towed?
also i have vacume in the crank case so i thought i broke a rocker but not that lucky.
I knew i was pushing it with stock head bolts.
find out monday when i pull her apart.
you might wanna check and see if its a valve seal instead of a ringland...do a compression test...
It is a cometic gasket and i can't really see it burned out but it has oil between the layers. and the intake is full of oil.
#2 & 8 are wet as hell with oil .the center 2 look to be dry.
last time i had it running it had vacuem sucking the oil cap on when i pulled it. and when i took it off it reved up a few hundred rpms wtf
no sign at all of detonation or valve to piston contact. I will do a comp test on the drivers side before i pull it but when i ran it last night with the coils off the pass side it did not smoke so i figured it was the pass side
thanks for the help.
It runs with out spray what it ran stock with a 150 shot 12.30 and with 150 it pulls the heavy pig gto to a 11.29@125 with a 1.89 60.
no idea how much power it makes but should i order arp bolts or studs this time or just gm bolt's?
at least it is not 5 or 7 and i have 7 good rods and pistons on the shelf that 1 will find a new home
and they already have arp2000 bolt's in them. i guess one good thing to come from breaking **** all the time is spare parts
I failed to turn off the tc while trying to get a stang to race me.while spraying and i am sure it leaned out.
either way the engine will be out and on the stand by this time tuesday.
but i am sure it has a big *** hole in the piston by looking at what was left of the spark plug
pulled it and the crank and bearings look brand new. so i have another already flycut piston and rod going in as soon as get home with a ring compresser tommarrow.
and she will be at the track this weekend hunting for that 10.99
thanks for the help
would have saved me pullen the pass side if i would have checked it the right way
