Going to have comp custom grid a TR230 what springs
Im trying to save as much money as I can.Im having Comp Custom grind me a cam to the same specs as the TR230 Anything on it I should have changed when i do the grind?what springs and pushrods should I use?Thanks and sorry for so many questions
Re: Going to have comp custom grid a TR230 what springs
Price and the lobes it looks like. The thread right next to this will explain that all. Not the exact same cam, but it will be close.
RJF, you can't really know the TR230 specs exactly unless they tell you all of them. (which they don't)
Alot of it depends on what you are looking for in the cam, more lift, less lift, longer spring and lifter life etc.
Bret
Bret
I would like to buy the real TR230 but dont have the extra cash for it.I couldnt make my mind up and still cant when the gp was one I was also looking at the 224/224 .581.581 on a 112 so i could get some lope I really want the TR230 what all specs would I need to know to have a custom grid done?
SN95 Director
918 springs. They are good for 620 lift and they are lighter. They have a bee hive design and the retainers are half the weight. Also, you might wnat to use an XE-R lobe. It's more aggressive and has more lift. How high do you want to tack the car? Are you going with a 230/224, 230/227 or 230/230?
The cam is a lot cheaper Im getting a very very good deal. Im wanting the 230/224 as far as tacking it just enough to get the power band right without reving to high
Angie
!LS1 11 Second Club
I just bought a TR230 for $250 (used w/ 3000 miles) on ebay. Keep an eye on the parts for sale section of this site.
I would use 918 springs with that cam, even if you do chose to go with something like a XER 230/224 cam.
1 Post
I would save up some scratch and buy everything you need from Thunder. If you have ANY problems they are there to take care of you etc.
Lee
Lee
RJF, the cool thing about using the 918's is that you can save some money by using the stock retainers. These would be your most economical spring and they hold to .600 lift.
If you want cheap and dirty then go with the hotcam kit. 400 bucks and you get the springs and stuff.
http://www.sdpc2000.com/cart.asp?act...1&pid=1089
Then when you can afford it get the H/C package you really want and sell the hotcam.
I have some low mile 918's with titainium retainers for sale. 190.00 shipped. The are blue stripes too.
email me at jsbird98@comcast.net if interested.
J
J
Lee
Lee
Lobe Style (XE/XER)
Intake Duration (advertised)
Exhaust Duration (advertised)
Intake Lift
Exhaust Lift
Lobe Centerline
Lobe Separation Angle
Cam Advance (if desired)
