Oil pressure problem
Old Sep 19, 2003 | 01:58 PM
blu00rdstr's Avatar
Default Oil pressure problem
Can anything else besides the O-ring cause low oil pressure? How can I tell if I'm pumping foam?
There's no tappet noises or lack of oil under the valve covers. Is it possible pressure is good, but pressure sensor or grounding is wrong?
This is a C5 with a double-roller and stock pulley. My crank pulley seems to be exactly inline with the other pulleys. I've heard C5s with double-rollers need a machined pulley. Could this affect oil pressure?
My mental checklist:
- Oil pump - New LS1 pump, has spacers but sprayed with sealer, double O-rings, tightened pickup tube before bolting pump body on block
- Crank - Tight bearings .0020 clearance
- Eagle rods - Flat sides together on crank
- Cam - New bearings
Old Sep 19, 2003 | 02:01 PM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Oil pressure problem
Did you install the rear oil galley plug behind the rear cover during assembly?
Old Sep 19, 2003 | 02:05 PM
blu00rdstr's Avatar
...rear oil galley plug...
hmmm
Old Sep 19, 2003 | 06:46 PM
blu00rdstr's Avatar
I'm trying to remember, anyone have pics of the rear of the block?
Old Sep 19, 2003 | 08:43 PM
MaxedOutSS99's Avatar
I read in the other thread that your using your old and a new o-ring. if this is true dont use the old one. The old one is too worn out to be put back in even if your going double. Thats what I think your problem is. Something similar happend to me. Try it, i may be wrong though.
Old Sep 19, 2003 | 11:23 PM
blu00rdstr's Avatar
Thanks, that's hard to believe though. I put both rings on, and with the tube inserted into the pump, there was about 1/16" gap before bolting the tube tight. I'm sure that this squeezed the O-rings tight and made a tighter seal than usual...
Old Sep 20, 2003 | 08:46 AM
DaleMX's Avatar
Maybe it's too tight on the o-rings and split them.
Old Sep 20, 2003 | 10:59 PM
blu00rdstr's Avatar
Jason99T/A: Did you install the rear oil galley plug behind the rear cover during assembly?
Doh!
I tilted my old block forward, and something was sticking out of a hole in the back. Must be that plug thing.
This is what a new plug looks like installed (unstained white plastic):
Old Sep 21, 2003 | 12:38 AM
Jason99T/A's Avatar
That would be it! I would replace it with a new one from GM. The part # is 12558340.
Jason
Old Sep 21, 2003 | 02:43 AM
blu00rdstr's Avatar
Thanks Jason!
That was however, stupid of me to overlook that part. I gotta pull the motor to put that little part in, I can't imagine a more buried place to put it.
Old Sep 22, 2003 | 09:00 AM
robertbartsch's Avatar
...not sure about a C5 but in a f-body I think you just pull the tranny; right? ...a lot easier than pulling the motor...
Old Sep 22, 2003 | 10:43 AM
blu00rdstr's Avatar
I wish. C5s have torque tube between the transaxle and engine.
Last night I was lying underneath with a drop light, staring at the bottom and wondering how far I have to pull the motor just enough to put the one little plug in.
Old Sep 22, 2003 | 03:56 PM
Country Boy's Avatar
Senior Member
The one in the pic I sent ya is a new one. Its the same plug, just unused
Old Sep 22, 2003 | 03:57 PM
Senior Member
I wonder what would happen if you reused the old one????
Old Oct 20, 2003 | 12:29 AM
blu00rdstr's Avatar
Update: Cause of low oil pressure was the missing plug...
Old Oct 20, 2003 | 05:37 AM
EVIL's Avatar
hmmm....now i wonder if mine is missing. i has low oil pressure before, replaced the o-ring and all the berings in the motor and still was low, but not as low. ARG!!!!!
i sure dont remember that little plug!
Old Oct 20, 2003 | 11:52 AM
Beeler422's Avatar
Back in the staging lane
I don't remember it either Brian, and I have low oil pressure. ****!!
