question on l92 setup
Old Nov 13, 2008 | 08:49 AM
ls1blazer's Avatar
Default question on l92 setup
The engines is a iron 6.0(.030 over) , weisco flatops w/l92 relief , WCCH cnc l92 heads milled .045 , l76 intake , ls7 head gaskets, 226/232 .609/.604 113 lsa, 1 3/4 longtubes, no cats (true duals), t56 trans.
It only made 400rwhp / 383rwtq with a tune . It seems a little low to me. Any sugestions?
Old Nov 21, 2008 | 09:58 AM
ls1blazer's Avatar
no help?
Old Nov 21, 2008 | 10:05 AM
the_merv's Avatar
Veteran: Air Force
What was the RPM's that you spun it too? What was the peak RPM's it made that at?
It's a 370ci Engine, what's the Compression Ratio?
Old Nov 30, 2008 | 10:44 AM
CBIII's Avatar
my similar build (408) did 426/427. I was pissed. MY heads/cam/exhaust are all too small and my tune is off though. I imagine you need to look at your tune and new cam.
Old Nov 30, 2008 | 12:22 PM
the_merv's Avatar
Veteran: Air Force
^^What H/C Combo are you running?
Old Nov 30, 2008 | 01:07 PM
CBIII's Avatar
massive ported 5.3s (2.065/1.55 valves, flowed 319@600 and 298@500) and TSP 231/237 cam, vengeance racing ported 92/95mm REVX TB, 1 3/4lts/ory/bullet m6/10bolt.
also, was done on a dynomite dyno.
Old Nov 30, 2008 | 01:15 PM
PREDATOR-Z's Avatar
What was the dyno? Mustang/dynojet etc..
What is your diff?
Size tire?
BTW pistons are Wiseco
Old Nov 30, 2008 | 01:21 PM
66deuce's Avatar
i would look at your tune first to make sure everything is right..those L92s like more timing thrown at them than the LS1/2/6 heads..
there's a couple of guys on here that have a lot of experience with L92 builds.Edcmat is one,i think that's how you spell his screen name..he's a sponsor on here..
Old Nov 30, 2008 | 08:57 PM
ls1blazer's Avatar
What is your diff?
Size tire?
dynojet, 10 bolt 4:10s, 275/40/20
Old Nov 30, 2008 | 09:00 PM
ls1blazer's Avatar
6200 rpms , I can't remember the peak rpms , 10.5:1
Old Dec 1, 2008 | 08:17 AM
Gen414's Avatar
Seems like cam is a little on teh small side with the duration, but really should not be the whole problem, should have made more still. Look at tune, and when you think you have looked at all the small stuff, look again. What was AF ratio? Plugs? Fuel pressure? Throttle body size? Is it opening all the way?New motor/just together? New combo? Old combo, new problem???
Old Dec 1, 2008 | 09:09 AM
the_merv's Avatar
Veteran: Air Force
The Duration is good..right in the area of most of the ones in that range..
Old Dec 1, 2008 | 08:07 PM
ls1blazer's Avatar
I physically looked at the tb and it only opens 83% but I was told this was normal by HP tuners with the trailblazer and ssr programs(the one I'm using with the ls2 tb) . f/p is fine, plugs are fine(tr6/.35),A/F ratio is 12.8-13.0 at wot. I even put the maf directly on the tb to see if the air intake was restricting the flow.
