Stroker's come in
Jon
Catch can will be next.
Jon
I ordered valve seals from SDPC a month ago so when we got to the point of pulling the intake to replace the valley cover, I would have them just incase. The valve seals seemed to be seated OK so none were replaced yet.
Jon, thank you for your offer and I will be taking you up on it soon if what we are about to try doesn't work. I really do hope to have this problem resolved very soon. This engine came out of my car on July 5th.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
There's a little more info on the PCV catch-can setups from Rev Xtreme.
All valves are like this. If you go with the incorrect theory that its the rings than you must also believe that if you dump a gallon of water in you living room floor that it will show up as a puddle on your roof.:think:
I upgraded all of Davids PCV system by removing his intake manifold and installing a LS6 valley cover which improves the CrankCase Ventialation by pulling crankcase pressure threw the valley rather than threw the valve covers. I also installed a new PCv valve. I then removed some valve springs and a checked his valve seals. All checked out. With any aftermarket ported Heads the intake runners will be ported to the point that the intake rocker bolts will protrude into the runner. So I tefloned and locktight those bolts to seal them. When hunting issues like this down and dealing with a company like TSP who does not want to accept there product is at fault. You will need to go down the list and correct all that COULD be the issue when the whole time I know its the Valve guides and Seal combination. If they want me to chase down possibiltys then fine, I will. As you can see with the pic above this is a substantial amount of Oil and could only be there with a Head issue. Im no specialist, but will get Davids ride smoke free. End of Mission Statement :thumbs up:
