Tap Tap Tap??
Old Nov 19, 2008 | 09:03 PM
Pro52R's Avatar
Default Tap Tap Tap??
I have NO idea where its coming from. Bottom end or top...
The engine has 100K on it (short block)
I replaced the timing chain,oil pump,cam,push rods, (lifters from a 50K mile car)
I get a lil piston slap on a cold start up, but then I get this tap tap tap noise.
It is noticeable at idle,but with some RPM's it seems to quiet down. (could be due to the open y-pipe)
I am showing 60psi w/ 15w40 Castrol Tection diesel oil.
Would a bad lifter or bearing get quieter with more engine speed?
I just really can't tell where its coming from..I guess I need to break out the pvc pipe
Old Nov 19, 2008 | 09:06 PM
Gregorya24's Avatar
why would you put diesel oil in your car?
Old Nov 19, 2008 | 09:35 PM
Pro52R's Avatar
it free....and i just wanted to run it for the initial start up.
Besides..its no different....just thicker...people been running it for years
Old Nov 20, 2008 | 09:24 AM
fortmyerspolice's Avatar
Sounds like the average LS1 noise.
Old Nov 20, 2008 | 09:29 AM
adriangarcia404's Avatar
i have piston slap also.=(
Old Nov 20, 2008 | 09:46 AM
novaflash2002's Avatar
pison noise, preaty common in ls1s
Old Nov 20, 2008 | 12:42 PM
Pro52R's Avatar
the piston slap goes away...then I get the tap tap tap....and like i said, it goes away when i rev it
Old Nov 20, 2008 | 10:37 PM
i know i have a ls1 that i have put a mechanic stethiscope on, and it keeps tapping on no 7 cylender. pistons can shrink with time. my dad is a machinist and has been building engines since the early 60's can confirm. im taking over his legacy, some people think im joking when i say pistons shrink, but i have seen it happen alote.
