need help on cam choice in a 370
Old Nov 21, 2008 | 08:01 AM
LS 60 APACHE's Avatar
Default need help on cam choice in a 370
hello! guys and gals.im trying find the best choice on a cam for my 370 ci ,l92 headed based 6.0 it is a street driven truck,so lots of bottom end and streetable torque is the aim im looking for.this will be in my 60 chevy short bed and will be using all truck components.all info greatly appreciated!!!
specs:
l92/l76 truck intake,wiring and pcm.unless better intake becomes available
as cast l92 heads cut to 68cc 823 casting
9.6:1 compression
4l80e trans
as of now i have a 3:07 gear but will probably go to a 3:73
Old Nov 21, 2008 | 08:52 AM
PREDATOR-Z's Avatar
224/230 .609/.604 111+1 LSA
Custom XFI/XFI comp Cam
Old Nov 21, 2008 | 08:56 AM
regency's Avatar
^^^^ and the ? is answered ^^^^
Old Nov 21, 2008 | 11:16 AM
PREDATOR-Z's Avatar
I would bump compression a bit to at least 10:1, what size reliefs do you have?
Old Nov 21, 2008 | 09:30 PM
thanks for the input.i was hoping to get a 10.1 comp ratio, could not find any lq9 flat tops that would fit my press pin rods, these sealed power hypereutectics that i have have a 11cc dish.my static comp. ratio with a .041 gasket gets me in the 9.6:1 range.it may be possible to trim my heads a couple more ccs. the piston is out the hole .004 so my PTH clearance is close to borderline.may have to step up in gasket thickness.
thanks again. oh by the way! what kind of idle would this cam produce!
Old Nov 21, 2008 | 09:42 PM
spray_goat's Avatar
with the lsa on a 111+1 it will sound pretty darn nasty at idle. My cam is on a 111 and it is sweet
Old Nov 21, 2008 | 09:57 PM
2THOUSANDZ's Avatar
I'd give Ron@Vengeance a call or shoot him a email about a cam. Mine is a 243/247 from them. Makes great power and torque!!!
Old Nov 22, 2008 | 01:17 AM
PREDATOR-Z's Avatar
.041 gasket and .004 piston deck height is .037 quench. Very respectable and nowhere near borderline. Keep the gasket as such. Just mill the heads a bit more. If you like I can tell you exactly how much with that cam.
224/230 111 LSA is 5* overlap, so noticeable lope but not outrageous.
If you like it PM me and I'll give you the specs and work out your chamber size for best static compression and dynamic.
Old Nov 22, 2008 | 09:06 AM
PREDATOR-Z's Avatar
I replied to your PM
Old Nov 22, 2008 | 09:24 AM
user 70810891082's Avatar
I have this cam on a different LSA... click my sig for a vid.
Old Nov 23, 2008 | 07:05 PM
Ryan L that idle video sound killer!! what is yor lsa if you dont mind me asking?? wider ,narrower?
Old Nov 23, 2008 | 07:23 PM
Old Nov 24, 2008 | 07:03 PM
thank you! forgive me for being a dummy,but the +2,is that 2 degrees cam advance???
Old Nov 25, 2008 | 01:11 AM
PREDATOR-Z's Avatar
Yeap.
Old Nov 27, 2008 | 02:22 AM
2manycars's Avatar
If he is running a stock torque converter with that size cam I would imagine compression would have to be bumped up to keep from having surging issues.
