Trex and TFS 215 can it be done
Old Nov 23, 2008 | 01:47 PM
ElectronSS's Avatar
Default Trex and TFS 215 can it be done
I was looking at using the TFS 215s on my 346 and using them with the following combo...Ported fast 90, kooks 1 7/8 lts, EWP, UDP and Trex
I tried a search and havent seen anything with this combo. would PTV be an issue with the angle of the valves with the TFS heads?
any insite would be appreciated
Old Nov 23, 2008 | 02:14 PM
35th SS's Avatar
dont think so.call Thunder Racing to make sure.
Old Nov 23, 2008 | 02:23 PM
KMS.1320's Avatar
yeah but why would you want to do that?
Old Nov 23, 2008 | 03:06 PM
RZRSEDGE's Avatar
Those heads would gain you better PTV clearance than the stock heads. So yes it can be done. No idea on how much clearance though.
Old Nov 23, 2008 | 03:42 PM
redtail2426's Avatar
Just make sure you have at least 11/1 compression with a setup like that.You will want to mill the heads to do that and will probably have to flycut,but it will surely be worth it.
Old Nov 23, 2008 | 11:04 PM
ElectronSS's Avatar
im familar with compression and Trex, I know thunder is a sponsor but do they have any personal on here i can PM and ask?
Old Nov 23, 2008 | 11:48 PM
chuckyt1's Avatar
Geoff, that's his screen name also.
He's at Thunder. Shane, too but I don't remember his screen name. Great guy's who will answer all your questions.
At least they were, I've been off the boards for awhile...
Old Nov 24, 2008 | 08:41 AM
sciff5's Avatar
TREX is meant to fit under stock heads without flycutting..
Trick flows supposedly have more PTV clearence than stock..
Just based off these 2 things I would think it should fit fine.
BTW sounds like you would have at least a high 400whp combo there. On some dynos you might hit 500whp. Would be a strong runner for sure, but will cost you a pretty penny.
Old Nov 24, 2008 | 08:45 AM
firefighter813x's Avatar
It would be interesting to see the results of this combo.
Old Nov 24, 2008 | 10:31 AM
ElectronSS's Avatar
wanta play gota pay. as for some parts of the equation i already have some of them. this be mated with a 6spd as well with a 9"
Old Nov 24, 2008 | 11:17 AM
sciff5's Avatar
Sounds good, get it together ASAP and throw it on the dyno and lets see what she does.
Would be good to see track times too. Good luck with it.
Old Nov 24, 2008 | 07:10 PM
MeangreenHD's Avatar
i thought 9" rears sucked up more hp than a 12?
Old Nov 24, 2008 | 11:19 PM
USMC Devil Dog's Avatar
Personally I prefer the 60, anyway, with power like that like the man said "ya wanna play gotta pay"! I like that!
Old Nov 25, 2008 | 01:10 AM
SS DNA's Avatar
Im sure they fit no problem. Just dont mill them. As someone said they offer better PTV clearance than stocks and the Trex will fit with stocks no problem.
Old Nov 25, 2008 | 01:30 AM
ElectronSS's Avatar
12bolt good for auto, 9" better for 6speed cause of the shock from the torque arm
Old Nov 25, 2008 | 05:39 AM
if you dont mill the heads your wasting your money.
Old Nov 25, 2008 | 10:27 AM
RyanM02's Avatar
Better then sucking up your wallet
Old Nov 25, 2008 | 10:37 AM
sciff5's Avatar
+1 12 bolt may suck up a little bit less hp but its deff not bullet proof where as the 9" is.
Old Nov 25, 2008 | 11:26 AM
PREDATOR-Z's Avatar
One thing I always wondered, why no aftermarket Dana 44 like in the 3rd Gens?
Old Nov 25, 2008 | 12:35 PM
want297z's Avatar
Strange S60 is a Dana based rearend.
