Best undercurve cam?
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
its got sick mid-range ( under the curve ) A cam doesn't need to be larger, plus larger cams
are more peaky an a 346cid motor. The cam above or the TR224 112lsa would be both nice.
are more peaky an a 346cid motor. The cam above for the TR224 112lsa would be both nice.
Not hero worship, just vouching that for 'free' advice and non-conventional thinking..might listen to him.
Especially with stock heads and your driving requirements. If you are willing to mix up some lobes and understand the valve events, you might be able to get exactly want you are looking for.
Have fun. No cam war, just sharing my experience.
..WeathermanShawn..
Then you just determine how much overlap you can live with, and where you want to peak your HP at.
Blanco is right that tons of 224 cams have proven to be phenomenal on both the track and street.
Some of the 'bigger' cams really shine as you bump up the compression. If you wanted to try a 228, how about a 228/228 111+3. If I calculated correctly, IVC ~42, EVO ~48. Overlap 6 degrees, so more than the 224 series cam.
It is getting a little late, so if someone wants to double-check my math and valve event terminology, please do.
Many of the sponsors can elaborate, along with Mr. Patrick G. Texas Speed just did a ton of dyno work, and if you can spring for heads..you will never look back.
I'll give ya three different choices for stock heads, and let the cam experts comment:
1). 218/224 113+1 Overlap: -5
2). 224/224 112+2 Overlap: 0
3). 228/228 111+3 Overlap: 6
All have similar IVC's & EVO's. Like I said, double-check my figures..sometimes with differing lobes and ramps rates, it can change some of the valve event figures.
Hope I didn't make it overally confusing. Your question of "Best undercurve cam", will always attract a lot of interest and differing opinions.
Cam choice is fun. Hope you find it just as intriguing.
Good luck.
..WeathermanShawn..
https://ls1tech.com/forums/attachmen...110lsadyno.jpg
and that is with XE lobes
, 224/224 .565/.565 110+4 LSA, cam only + bolt ons (the right bolt ons for the job)405rwhp/406rwtq (corrected)
Remember guys, COMBO< COMBO< COMBO (total COMBO for task desired)
BTW (just to tease you), this was done way back in 2002/2003
what else besides a dyno tune and ls6 intake should I really be looking for to optimize the combo?
When you make a statement like "TR224" is the mother of all 224s and no one can do better, I only showed you that it is not quite so in reality. You have to realise that lobes have evolved.
That 224 XE has a ramp rate weaker than TR proprietary lobes on that 224. It makes more undercurve for the simple reason being that the VEs are right for the combo at hand.
You cannot just choose a lobe and say this will make the most. You have to decide on powerband desired,choose VEs, match lobes, look at various lifts, all of this while knowing exactly how the rest of the motor/drivetrain combo parameters will fit in.
What is a custom cam? surely you know that the cam is the last item that goes in a motor build not the way around.
The beauty of the variety of lobes and rates we are offered nowadays, is that it gives us more to play with than back when TR224 was designed.
Reality is it can be done, it has been done, I can do it too
Oh and just to set the record straight, that XE cam was not one of my creations, a member named DAPSUPRSLO ran it back then 02/03, it came to light way back in cam discussions (before LSK<XFI<LSL<LSr lobes were created).
Mixing and matching lobes is not new either ...LOL and guess what I've got an L92 cam here with mixed lobes as well. It was developed for an ls2 for a daily driver.
But lets see a side by side test as suggested. Not a dyno sheet from 3 years ago...LOL, you know that proves nothing at all. No disrespect intended.
Let see a tr224 112 lsa and your cam strapped into the same engine and post some results. Thunder developed that cam how long ago? It still rocks and has been mimicked by countless people a number of times. I guess thats the sincerest form of flattery.
