230/230 cam with stock ported 241's?
Old 01-13-2009, 06:22 PM
  #41
W es 6's Avatar
I was planning on going with a Torquer v2 in my DD but the more I read about this cam the more I want it lol. Just when I thought I had finally made up my mind, here comes another great option!
Old 01-13-2009, 08:07 PM
  #42
Zach79Z's Avatar
trust me i know how you feel. Ive picked out about 4 cams since i decided to go cam only
Old 01-13-2009, 08:35 PM
  #43
regency's Avatar
Originally Posted by chrs1313
Well going by my clearance of .086 intake -.014 (differ mls to cometic) -.010 mill, I would say u are around 0.062 intake so say you are at .060… so I would say to be safe at least 0.025 depth…
This is assuming the ls6 heads and 241 heads have the same PTVC stock…if the ls6 has close to 0.025 more you will probably be able to get away without even flycutting…anyone know the difference gained or loss from 241’s to 243’s?
hmm.. i wonder where i can find that info?!! I cant seem to find all the clearances
Old 01-13-2009, 08:41 PM
  #44
Zach79Z's Avatar
I figured there woulda been a thread about ptv clearance between 241 and 243's somewhere
Old 01-13-2009, 08:49 PM
  #45
pcs9449's Avatar
Originally Posted by blwn_00gt
11.75 is more than .20 away from a 10.81.
Sorry, I didn't read the stock internals part, stupid me.
Old 01-13-2009, 08:52 PM
  #46
Zach79Z's Avatar
when he ran 11's with the 3600 was without a cam i beleive cause it says stock internals with a 3600 stall and the 10's says cam only with 4000 stall
Old 01-13-2009, 09:44 PM
  #47
pcs9449's Avatar
You're right, my bad, I guess I should get some sleep. DOH! At any rate, good luck with your setup!
Old 01-13-2009, 09:49 PM
  #48
Zach79Z's Avatar
lol it took me twice to read it when i seen it lol. Thanks i hope she rolls out nicely
Old 01-14-2009, 07:43 AM
  #49
chrs1313's Avatar
i would go with this cam over the tq 2 it will make slightly more power...you were in the exact same position I was in, I wanted a cam that made big tq and big hp without sacrificing driveability, I almost got the tq3 but the intake lift was way to high for my liking...i wanted a max effort daily driver cam...
Old 01-14-2009, 08:16 AM
  #50
99T/AMAN's Avatar
so how/where can i get one of these el-torro cams?
Old 01-14-2009, 12:47 PM
  #51
Zach79Z's Avatar
You gota order it from comp as a custom grind. I ordered mine through vengeance racing
Old 01-14-2009, 02:42 PM
  #52
SSmoken's Avatar
thats what I plan on doing too.
Old 01-14-2009, 04:10 PM
  #53
Zach79Z's Avatar
good plan
Old 01-14-2009, 04:22 PM
  #54
LS1_K1DD's Avatar
Same cam ill be going with. Aways down the road, but it'll be the same. Have some stuff to finish up first.
Old 01-14-2009, 06:01 PM
  #55
SSmoken's Avatar
good plan
did you just give them the specs and thats it ?
Old 01-14-2009, 06:43 PM
  #56
SOMbitch's Avatar
Pred-Z gave me lobe #'s but you can go on Comps website and look them up. It is an XFI/X-ER lobed cam with a 111+2 LSA. Lift is .612/598
I have the same cam with more exhaust duration because I am running cats...
Old 01-14-2009, 06:45 PM
  #57
regency's Avatar
in everyones opinion how much would you gain with this cam on a 111+2 over a 228R-112+2
Old 01-14-2009, 06:53 PM
  #58
blwn_00gt's Avatar
did you have to fly cut your pistons for your combo?
Old 01-14-2009, 08:07 PM
  #59
Zach79Z's Avatar
Basically yes. you can either tell them 230 230 .612 592 111+2 or give them these lobe numbers.
"The specs are (Comp Cam Lobes)
Intake lobe: 3016R XFI
Exhaust Lobe 3725R XE-R
111 LSA (lobe separation angle)
109 ICL (intake centerline)"
STRAIGHT FROM PREDATOR Z
If you order it from vengeance ron will want to get both to make sure they match
Old 01-14-2009, 08:09 PM
  #60
Zach79Z's Avatar
lol yours is 612 598 the 230 230 were talkin bout is 612 592
Quick Reply: 230/230 cam with stock ported 241's?
