ISKY Flycutting Tool for LS1
Need the correct tool for the job?
Here is the answer
I will be renting my "modified" ISKY 2-1/8" Flycutting (notching) Tool with the 5/16" pilot. It is a definite must-have tool to cut valve reliefs in the pistons to increase the PTV clearance for all of the big cams out there like the G5X2, etc. This tool has been modified to fit inside the combustion chamber WITH the valve seat installed. The head will sit perfeclty flat on the block for accurate cutting. Please send me an email or post here if you want to get on the list.
Rental Charge - $50 + shipping
Available in about 2-1/2 weeks
Thanks,
Mike
BTW, you can buy the cutting heads for $90 each & the shaft for $35.
I'm going to be buying my own in the next couple of months (when I get ready to do my fly cuts). I figure for the cost of renting them, I might as well just go on and buy my own set.
