engine combs
Old Dec 4, 2008 | 10:11 PM
1999FirehawkLS1's Avatar
Default engine combs
Looking to put in a 6.0L. Wondering if i should use my 5.7 heads that cam with the car on the 6.0 block or should i use the 6.0 heads that org. come with that motor.......and can i use a ms4 cam in both my 5.7 and 6.0 when i go to swap it out?
Old Dec 4, 2008 | 11:31 PM
the_merv's Avatar
Veteran: Air Force
Long Tubes are a better buy..the MS4 will work fine with the 6.0l, what kind of Heads are on the 6.0l? If they are 317 Heads I would use them, just get them milled down to make the Chambers smaller..
Old Dec 5, 2008 | 08:06 AM
NVR_SPDS's Avatar
Cam should be identical, and if your staying with stock heads, go with the ones from the 6.0. They will probably be 243 castings, as opposed to the 241s or other casting from the LS1.
Old Dec 5, 2008 | 03:15 PM
Default engine q's
ya thats what i herd but dont 6.0 head have bigger cc size and that would drop compresson right?
Old Dec 5, 2008 | 05:23 PM
if 317 heads are what come stock on a 6.0 blcok than thats what they will be havnt bought one yet but plan on it...how much should be milled off?
Old Dec 5, 2008 | 10:20 PM
the_merv's Avatar
Veteran: Air Force
Usually the general rule I have heard it's .005" for one cc out of the Chambers. I don't remember what they are stock, I'm sure someone will have that number.
Old Dec 6, 2008 | 06:22 AM
NVR_SPDS's Avatar
Depends on which 6.0 it is i believe.. The 317 castings, i believe are the truck castings, close to the 243s just bigger chambers, for lower comp.. Nothing a light mill wouldnt take care of, from what ive read.
Old Dec 6, 2008 | 06:51 AM
the_merv's Avatar
Veteran: Air Force
The MS4 will work fine in the 6.0l.
What kind of 6.0l is it..an LQ4 or an LQ9?
Old Dec 12, 2008 | 07:18 PM
elias_799's Avatar
are you going fi or na ? if you are going na i would get an aluminum 6.0 block (ls2) but that's just personal preference.
Old Jan 15, 2009 | 04:50 AM
well alum would be sweet but i think i might just stick w the 5.7l for now my fundings has changed and got to keep it reasonable
