I am about to O.D. on all this!!!
Old Dec 17, 2008 | 12:14 AM
nalmak's Avatar
Originally Posted by lemons12
this is true..
although i dont buy into the ms3 isnt a good choice because it doesnt make power until blah blah blah.......
if your racing, your at WOT... which means your going to run all the way up until 6500rpms or whatever your shifting at.. other than that.. doesnt matter what rpms you make power or dont make power with...
that is the reason i recommended the torquer 2 or 3... both very good cams and a tad smaller than the ms3 ms4..
224 is a bit small for my taste.. i would go with at least a 230ish cam.. but thats just me.. and im no guru..
i think im gonna go with the torquer 2 or 3..It seems good..Now i need my 241's...Oh BTW if you are just swapping heads do you still have to take the cam out or can you leave it in??
Old Dec 17, 2008 | 12:18 AM
lemons12's Avatar
you can do heads and the cam can stay in the car... the intake will come off, along with headers dipstick valve covers power steering yada yada yada..
Old Dec 17, 2008 | 02:03 PM
nalmak's Avatar
Exactly..Has anyone ever ran the T2 or T3?
Old Dec 18, 2008 | 04:49 PM
rice4eatingnotdrivin's Avatar
Ok..I swear my brain is melting from all this..I need some help like Whitney Houston on Crack..I plan on installing Cam/Heads/Intake/LT/X-Pipe or H, maybe going down to 3:73 (but 4:10's are too much fun!)..Anyway..I know Ls6 Intake is a must from a Ls1, New Oil Pump, Double Roller. etc etc..I know all that..I have been reading Patrick G's Cam Write-up, and been scrolling the boards reading about cam's and heads..I'm totally lost now..I know 243 are better than 241's, but i could get some cheap 241's port them and be good but i loose compression, i don't want a track car its only gonna a be a street killer thats all..Vr3, VR2, MS3, those camshafts are almost the same but whats the difference?,,What is the best street cam here?, Should i use 1.7 adjustable or 1.8 or non adjustable rockers?..PVC..What springs are good matched with a head and cam will a VR3, with 918's on a P&P 241 clear?..Need Mad Help....Thanks Guys
sorry to jump in on ur thread nalmak but there is one question that i dont think has been answered... is there any PVC issues with any of the cams mentioned with stock heads???
Old Dec 18, 2008 | 06:00 PM
lemons12's Avatar
no..
the only cams that that begins to start becoming a problem with are the ms4, polluter, trex.. then you have to use stock valves and shiznit..
you cant run regular 5.3 2.5s prc ls6 stg 2.5s...
you can use prc ls6 stg 1s and so on..
anything with stock valve sizes it will clear.
Old Dec 18, 2008 | 08:12 PM
kain01's Avatar
Car Craft has some good advice on what's needed to get at least 500 horses naturally aspirated. It's basic advice, leaving the ultimate build up to you. Just remember the things they suggest can be had for alot cheaper than summit racing sells them for.
Still it's good information for anyone to have.
http://www.carcraft.com/techarticles...ons/index.html
Old Dec 18, 2008 | 08:18 PM
lemons12's Avatar
According to Duttweiler, all it takes to make 500 hp is cylinder heads that flow 310 cfm or better along with a little more camshaft than stock.
disagree.. and its not quite that easy.... i didnt see a price for exhaust, oil pump, timing chain, etc.... you would need an under drive pulley and all the little bolt ons to get 500 on average out of an ls1..
Old Dec 18, 2008 | 08:25 PM
kain01's Avatar
Mind you he nor I ever said rear wheel horsepower. All those mods should net you 500 flywheel I would think.
Old Dec 18, 2008 | 08:30 PM
lemons12's Avatar
ahhhh ok... i was assuming.. i usually talk RWHP...
yes, it is easy to achieve 500 in an ls1... flywheel that is, not RWHP..
you could do that with a healthy cam, PRCls6 stg 1s, 90/90, and the usual bolt ons.. would be a lot cheaper than what he did..
Old Dec 18, 2008 | 08:31 PM
lemons12's Avatar
is a nice little read though!
Old Dec 18, 2008 | 08:38 PM
kain01's Avatar
Yeah most people usually talk RWHP on here so it's a safe assumption. You are absolutely correct on the other adders for 500 RWHP. The rest of the articles a good read too, but covers all kinds of engines.
Jeez I can't wait to get started on my car......wishing for 15k to pop in my lap....lol
Old Dec 18, 2008 | 08:48 PM
  #32
lemons12's Avatar
yea, i dont care about fly really.. doesnt mean much.. different drivetrains different loss in horsepower..
hahaha, would be nice...
Old Dec 18, 2008 | 09:33 PM
  #33
nalmak's Avatar
Thanks for the Info..Much Appreciated..Wish i had the same thing happen to me, only 15k every week....That way I might be able to get a discounted rate on Paris Hilton and Jessica Simpson..The going rate is pretty low I heard..J/K
Old Dec 18, 2008 | 09:36 PM
  #34
nalmak's Avatar
no..
Good to know that i can install the T2 with some 241 and be cool on PTC. But i might go with double springs just to be on the safe side, Xe-R or whatever lobes I heard are pretty aggressive, Maybe Ferrea Valves????..(Did i spell that right..Ahhh U know what i mean..
  #35
kain01's Avatar
If the going rate is low, how many others got the discounted rates for them to have that much money???? o.0
Ok I'm done hijacking the thread, can't speak for others though......
Old Dec 18, 2008 | 09:38 PM
  #36
nalmak's Avatar
I lost track at 12,763...
Old Dec 18, 2008 | 11:40 PM
  #37
lemons12's Avatar
yea you will be fine.....
i too would go with duals.. no reason not too.. just added precaution..
http://texas-speed.com/shop/item.asp...d=173&catid=48
http://texas-speed.com/shop/item.asp...d=172&catid=48
Old Dec 19, 2008 | 12:07 AM
  #38
nalmak's Avatar
Thanks Guys..Much Appreciated
Old Dec 19, 2008 | 12:11 AM
  #39
lemons12's Avatar
Old Dec 19, 2008 | 12:15 AM
  #40
nalmak's Avatar
Originally Posted by blue98Z
To the OP, what about the VRX4. It's kind of in the middle I also I think. I'm running that untuned at the moment and like it alot and cant wait to see the results after a good tune.
I have never heard of that cam...?Who makes it..What are the numbers??
