Patriot 5.3 head Question
I was just wondering if they would work on my 99 trans am, ive got pretty much all bolt ons besides heads/cam.. I will attach the pictures(if i figure out how) in which were sent to me. Like i said before, just wondering if these would work and what i should need to install them if they do. possibly which cam to run with these heads. casting number on the outside of the heads are 706 if that helps any
wich cam you should run.... damn i cant believe that question hasnt ever been asked on this board...
the good answer is : depends on what your goals are....
I ran these heads for 4 years with a TR224 and made power in sig... Great head IMO..
214cc intake runnner, 2.02I, 1.57E, 63cc chambers.
They are 61 cc's in the chamber. the intake valves are enlarged from 1.85 to 2.02 and the exhaust valves are still the stock 1.57. The rocker arms where stock ratio and I think the pushrods were to. The cam he used had 580 lift on both int. and ehx. . The duration was 292 on both. The guy knows his motors in all. They came off a Dirt track motor, I know him personally he wouldnt F me over. That was also my first thought to replace vavle springs and what not, and the price was sort of high if i have to resurface them and go threw them.
He also said i could buy the motor they came off which made over 520 hp and 485 pounds of torque on the dyno with stock heads, Not these heads. for around 3200 bucks. But I have 2 lt1's, and an iron 6.0, so im not really sure thats the route I'm wanting to go
I'd just buy a new set of Patriots for $995/$1049 or whatever before spending $800 on someone elses used stuff if I wanted Patriot heads.
