Headbolts
Old Dec 19, 2008 | 07:52 PM
WS6Drop's Avatar
Default Headbolts
If I change the headbolts but do not remove the heads is it necessary to replace the headgaskets? I am installing a set of ARP headbolts.
Old Dec 19, 2008 | 07:53 PM
jsteele90's Avatar
not at all
Old Dec 19, 2008 | 07:57 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Just be very careful. If you get fluid in a bolt hole and don't realize it, you will either snap a bolt or possibly crack the block when torquing the new bolt in.
Old Dec 19, 2008 | 07:58 PM
jsteele90's Avatar
Old Dec 19, 2008 | 08:22 PM
Shawn MacAnanny's Avatar
What i would suggest that i have seen done is people taking off the water pump hose and possibly thermostat housing and using a shop vac to suck out all of the coolant. This would help prevent any potential coolant from going into the bolt holes sine you wont be able to blow the holes out very well with the heads on the car. It would be worth the extra insurance for the $20 or so in coolant you'd be wasting.
Just curious, why are you replacing the head bolts?
Old Dec 19, 2008 | 08:29 PM
405HP_Z06's Avatar
A word of warning. The factory head bolts have a thread locker that is very hard. You need to clean this out to get the proper torque applied to the fastener.
Cleaning these holes is one of the most tedious steps and the biggest PITA of the whole process. I don't know how you can clean the bolt holes adequately with the heads still on. JMHO.
Old Dec 19, 2008 | 08:33 PM
Yeah i have heard the best way to clean the bolt holes is to take an hold head bolt and cut a groove down opposite sides of the threads to act as a 'tapping' bolt. The grooves will give the debris somewhere to go to when it gets re-threaded into the hole. Then you just blow the holes out.
Old Dec 19, 2008 | 08:47 PM
405HP_Z06's Avatar
ARP sells thread chasers for the LS1. I used them on my head swap and they worked great.
Big bolts - M11 x 2.00: part # 912-0011
Small bolts - M8 x 1.25: part # 912-0001
jsteele90's Avatar
now that i think about it. you might as well pull the heads all the way off if youre gonna do this. might as well replace the gaskets too.
Old Dec 19, 2008 | 08:52 PM
WS6Drop's Avatar
I am going to be boosted. I know studs would of been better, but I bought these before the procharger so I figured I would use them. I wanting to run about 8psi.
Old Dec 19, 2008 | 09:06 PM
nprather's Avatar
boost its not as violent as spray, only 8psi the bolts should be fine, but they are correct, you will need to chase the threads, and that will be harder with the heads on the car for sure.
Old Dec 19, 2008 | 10:19 PM
405HP_Z06's Avatar
ARP head bolts will be more than sufficient for your application, don't sweat it.
Old Dec 19, 2008 | 10:33 PM
WS6Drop's Avatar
Thx for the advice guys
Old Dec 20, 2008 | 08:18 PM
UNDER PRESSURE MOD
Again, just be very very careful when re-installing the new bolts. Hand tighten them without a ratchet and if you hit any tough spots before the bolt head his the cylinder head, stop, and back that bolt out and rerun a chaser through it. There is no worse feeling when working on a car then have a bolt strip, snap, or split the hole it's going into.
