Futral cam owners please com in!!!!
I am looking to bu a futral cam and was just corious what you guys are getting rwhp/tq #'s. PLease list cam number and specs and hp/tq# and ET's. Mine will not be a DD and i will do all support mods except heads for now. Thanks
I daily drive my F14 HL... 232/234 .646/.612 114lsa along with some Stage II Patriot Performance LS6 heads and a 125shot.
434rwhp/396rwtq SAE N/A
563rwhp/585rwtq SAE on a progressive 125shot
11.95 @ 119 on a 1.92 60' this past summer
11.13 @ 130.5 on a 1.84 60' several weeks ago.... stock 10bolt 3.90 gears
I used to dd my setup on stock gears. Futral F15, with supporting bolt ons. It made 394/368 SAE with the ls6 intake, 404/373 SAE with the ported fast 92.
Best so far of 12.0 @ 115 on a 1.71 60' in decent weather (have not run with the fast yet). It should run 11.7 as it sits at about 3700 raceweight. You'll love the low end tq any Futral cam makes.
I have the F-11 228/230 114lsa .576/.595. I have full bolt ons/fast92 combo/stall making 418rwhp/386rwtq. It made 386rwhp/366rwtq with the ls6 intake.
I wasn't looking to try and get a new cam for free- I just needed a new cam-period, and wanted to re-order the same basic grind that I had before. As good as the cam was, and they probably still are, I would be wary of any company that I could not contact after more than 5 tries! I tried all the different links Forum members recommended at the time, and even tried different times of the afternoon, morning, etc. Good luck!! P.S.- Futral cams, at the time of my purchase, at least, were ground on Cam Motion lobes. Kurt Urban, formerly of Wheel to Wheel Powertrain, highly recommended that I stick with Futral cams. And I would have, had I been able to order a new one from them.
I also think they still use Cam Motion lobes. There cams make a helluva lot of power. You see what lil' ole F-11 is putting out
Thanks for all the info guy i really appreciate it i have 2 buddies one ran the f14 standard(never dynoed it) and the other one is currently running a f14HL (on a Nitrous tune) so i didnt have any real good cam/motor only numbers. Thanks alot...P.S. my buddy with the HL had bad contact problems also but when he did get ahold of them they where very helpfull. Thanks
Cam Motion cams on average (making sure thats highlighted for all the Comp nuthuggers) make more power and have better driveability than the other grinds. I've done tons of cam swaps over the years, and Futral and/or Cam Motions have always prevailed in performance.
My biggest dislike about them, is valvetrain noise. They will turn your car into a sewing machine on steroids.
Formerly darynC-10/23/10
i have a futral FM5 224/228 600 lift on a 112+4 it made 350ish hp/350ish tq it pulls like a ****..
oh yeah thats my truck
oh yeah it does have valvetrain noise too, but i can deal with it.
In stock cubes I ran the F14 (232/234 with .600 lift on a 112) in my Z06. With the ls6 heads and that cam I was making 423 rwhp 408 rwtq. I was running a consistant 11.6-11.7 @ 119-120 with short times of 1.7 in the 60 foot. I eventually sold the ls6 heads and added Dart 205s milled for more compression. I was putting down 451 rwhp 423 rwtq with the dart heads with the F14 cam. I never made any good track passes on that setup because I cracked some pistons soon after the head install.
I dont go to Futral any more for tuneing but I can admitt that his cams are very good. I have used the f13 with great results( times in sig) and now am running the f14 with my 6.0 lq4 shortblock with great results.
In my Nova I am running his cam that he makes for 383's which is 239/243 @ .050 lift is around .612 but not sure on a 112 lsa +2 advance.
I have this cam because I bought it from a freind and I have a really light car with stock cubed ls1 at 11.7/1 compression with a 5300 converter. I have not ran this Nova yet but it sounds really good and leaves hard in my driveway. I am going to the track next sunday with it.
[QUOTE=AINT SKEERED;10742960]I dont go to Futral any more for tuneing but I can admitt that his cams are very good.
Y dont you use him anymore i was gonna trailer my car 11 hours after my install to have him tune it! NOt a good idea? PLease explain. Thanks for all the good replies..... Thanks ryan
I've actually been planning on getting a cam from them. A buddy of mine suggested the F6 112LSA. It would be going on my daily driver that right now has a cat-back, BBK throttle body, and K&N intake, all of which came on the car. I'm planning on adding an LS6 intake, pace setter LT's and y-pipe (already have these), valve springs, retainers, pushrods, and an LS2 timing chain, maybe an upgraded oil pump as well. Would this be a good match for my set up? Down the road I'm planning on adding heads and a 100-150 shot. Thanks for any help you guys can give me.
