degree cam?
Old Feb 17, 2009 | 11:06 AM
  #41
C5_Pete's Avatar
So, it seems to me that if you install a cam with a degree wheel kit and it all lines up fine (or close enough) then just use an LS2 timing set. If it doesnt then buy the adjustable timing set.
in other words, dont buy a timing set until you degree the cam.
Now here is another question. Cant you adjust the sprocket with an offset key? I've never held an adjustable timing set in my hands, so I'm not familiar with exactly what part is adjustable.
Good info here.
Old Feb 17, 2009 | 11:21 AM
  #42
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Good info here.
Good theory, but the chain sets themselves are one of the causes for the VE's being off from design. You can have one set and it be spot on, swap to another with the same part number and all, and be off several degrees. It's not just camshafts that can be off!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 17, 2009 | 07:09 PM
  #43
Irocss85's Avatar
exactly. your best bet would be to buy the gm chain if thats what you want, and test the cam position. and then yes, if its off you'll have to get rid of it and buy the adj. one. the chain/gears themselves are just one of the things, as mentioned, that could be the reason its not spot on where its supposed to be.
I think I have heard of an offset key for the LS1's. not sure though. that could poss. move it a tiny bit. but if its off, to me just buy an adj. set and your good to go no matter what else.
Old Feb 18, 2009 | 12:44 AM
  #44
darknessxyz's Avatar
So even with the degree wheel and the correct tool, you'll still be off with the LS2 timing chain set? I bought the LS2 chain set already and I don't wanna go through the adjustable one.
Old Feb 18, 2009 | 12:48 AM
  #45
HavATampa's Avatar
Maybe not. The only way to know if it's all lined up properly is to degree it. You may find that it's spot on with that chain and you won't have to adjust anything. You may also find it's off a few degrees and you won't be able to sleep at night if you don't make it right.
Old Feb 18, 2009 | 12:57 AM
  #46
Ok, let's see if I understnad this correctly;
After install the LS2 chain, I've to degree it with the wheel. If I spot on, I'm cool. If not, I've to change out the LS2 chain for adj. chain to degree it. Correct?
However, Predator-Z has mentioned this, how does he degree with LS2 timing chain with the degree wheel?
Originally Posted by PREDATOR-Z
Actually yes, you can adjust any timming chain if you know what you're doing with a degree wheel. I run LS2 chain/gears and just move around the gear.
I use paint to make my marks for reference. There is no magic in the adjustables, they just save time.
Old Feb 18, 2009 | 01:05 AM
  #47
HavATampa's Avatar
Yup. Once you check it and it matches your cam card, you can slap it back together and feel confident you are making your engine happy...mechanically anyway. I saw the post earlier by Predator and was wondering what he meant too. Maybe he will come back later and explain. Maybe jumping a tooth on the gear to fix an out of whack situation?
Old Feb 18, 2009 | 11:40 AM
  #48
Hugger's Avatar
Has anyone ever run across a GM cam that was off? Say something like an LS6 cam or Hotcam, are they ever off? Seems like GM's would be right on the money. Just curious.
Good info in this thread.
Let's say you had an LS6 cam and it degreed correctly. What would happen if you advanced it 4 degrees, what about retarding it 4 degress?
Old Feb 18, 2009 | 04:58 PM
  #49
bonestock99's Avatar
Advancing a cam brings the powerband lower in the rpm range and retarding it raises the rpm of the powerband but bottom end drops off pretty fast!
Old Feb 18, 2009 | 09:20 PM
  #50
Irocss85's Avatar
ever notice 2 identical cars same car, same mods, and one is way faster?
Old Feb 18, 2009 | 09:25 PM
  #51
HavATampa's Avatar
Thumbs up
Ahhh, makes sense!
Hate to get off topic, but funny you should post something at this very moment Irocss85. 20 seconds ago I gave your link to How to Flycut Pistons to a new guy on the board. Good job on that and thanks for sharing it with everyone.
Old Feb 18, 2009 | 09:28 PM
  #52
Irocss85's Avatar
cool! glad to help anyone I can. I was learning too when I did it, and figured alot more people might feel comfortable about goin ahead with the "right" cam instead of a smaller one just because they were scared to flycut. I was actually goin to do a write up on this subject too but I found enough sbc ones online already figured it wasnt really nec.
Old Mar 16, 2009 | 05:19 PM
  #53
1fastmofo's Avatar
i got my degree cam kit...but i already have a ls2 setup im waiting preadator too...
Old Mar 17, 2009 | 07:07 AM
  #54
utahws6's Avatar
if im thinking correctly..on the ls2 timing chain...you would just move your cam on the chain seperate from the crank...(...jumping a tooth or two.)...untill your cam dials in where it should be..if ur dots dont line up anymore..then once you have it where u want..u can make your own dot...so that u know where your at with that gear set in the future...the seperate keyways are just giving you automatic points of reference...but with out them u would just go by tooth rather than keyway.
Old Mar 23, 2009 | 07:36 PM
  #55
1fastmofo's Avatar
this is what i plan to do unless someone can confirm it will not work
Old Mar 24, 2009 | 09:34 AM
  #56
fast's Avatar
a tooth is a lot, not very accurate, but as Pred-Z stated mark it and try it, might not work for everyone or it might get you close
Old Mar 24, 2009 | 05:19 PM
  #57
Irocss85's Avatar
well, your not goin to just "try it" are you? what pred. Z is talking about is moving it, then SEEING EXACTLY how it affects the position of the cam. you can get away with a few deg. either way. but I think he means either to advance/retard the cam an exact amount, or if its off a deg. or two or three, see if one of the other key's gets it exactly on. he didnt mean just change the position, and see if it runs ok. that could be disastrous. with valves crashing into pistons all over the place.
Old Mar 31, 2009 | 07:46 PM
  #58
1fastmofo's Avatar
right i understand that sorry guess my post was confusing. I wanted to know if some one knew how much one tooth would add up to in degrees?
Old Mar 31, 2009 | 08:46 PM
  #59
Kurtomac's Avatar
i had my cam doctored...spec was 108icl and the cam doc said 108....now if i install dot to dot what am i checking for?...sorry cam degree dumb here
Old Mar 31, 2009 | 10:36 PM
  #60
bigdsz's Avatar
Comp sells an infinitely variable sprocket that's reasonably priced. I'm on my 4th cam using it. I change my chain from ime to time, but the sprocket is like new after about 65,000 miles.
