Cam Choice for carb motor
Old Jan 5, 2009 | 04:34 PM
  #41
1997bird's Avatar
Originally Posted by luckyhenriksen
Oh great those prices look better. Is there a certain length I need or are those all for stock motors
If you use the stock piston's then you will end up useing part # 2-ICR6100-944P. If you choose to buy new pistons then you will use either 2-ICR6100-927 or 2-ICR6125-7/16.
Old Jan 5, 2009 | 05:29 PM
  #42
luckyhenriksen's Avatar
Thanks for so much help 97bird, what would you suggest as a good piston for the stock bore, with stock L92 heads. Something strong, not too expensive, and able to produce good compression for a street motor.
Old Jan 6, 2009 | 04:36 AM
  #43
1997bird's Avatar
I found three companies that make a piston to fit your application. They all use the 6.125" long connecting rod (2-ICR6125-7/16). The most expensive will probably be Diamond, part # 11541, I did a quick search and the cheapest that I had seen was $627.99 w/o piston rings. The next was a Weisco part # K398XS that comes with rings for the year 2009 according to thier website, but I was unable to find internet pricing for it. The last piston part number that I have will probably be the cheapest of the three. Mahle makes a piston & ring kit part # L92314000F04, but again I was unable to find internet pricing on it. I would call several of the sponsors and try to get availability & pricing for them. Sorry I couldn't find more info for you but I'm out of energy after putting a 20 hr. day in.
Old Jan 6, 2009 | 09:13 AM
  #44
TJ's Avatar
TJ
i just bought some new srp pistons from jegs. they were 560 with rings. they arent for big shots or boost. putting the motor together right now.
its another option for you. budget pistons and rods, you could forged the bottom end pretty cheap.
Old Jan 6, 2009 | 09:38 AM
  #45
Ok thanks guys, I am not planning nitrous/boost yet, I just don't want to break stock pistons. Would it be totally worthless to use new rods with the original pistons?
Old Jan 6, 2009 | 10:41 AM
  #46
TJ's Avatar
TJ
yes. waste of time.
id do pistons and rod bolts and reuse the factory rods before i put the factory pistons back in on good rods.
good luck.
Old Jan 6, 2009 | 06:50 PM
  #47
Alright maybe I will just keep saving for a stroker rotating assembly lol.......
Thanks guys
Old Jan 6, 2009 | 07:06 PM
  #48
Shawn MacAnanny's Avatar
I wouldnt run boost on stock pistons on rods but i would say go ahead and run NA stock rods and pistons. My engine took a hit in the oil pan when i had bought it. Timing cover was smashed, oil all leaked out. Figured it was shot but stuck it in anyway. I did a compresions test 7 cylinders were 0-30 pise and 1 was 130psi. I installed all my stuff anyway let it heat cycle and today every cylinder compression test at 165psi within 2 psi. It's really NOT that hard to pull an engine and rebuild is especially in your truck.
These guys are usually talking about being in 4th gens or vettes where engine removal can be a pain in the ***. I can remove the engine in my firebid in less than an hour if i had to. I know it might be double work but if you dont have the money, you dont have the money man.
Old Jan 6, 2009 | 08:08 PM
  #49
Ya I don't mind swingin the engine in and out, the bay in my truck is cavernous. Plus, if I am putting something better back in, I am more than happy to yank it out =]
