Cam Choice for carb motor
Hey, I am planning my motor build and need advice on the cam. It will be a stock bottom end 6.0, L92 heads, GMPP intake and an 850 carb. I want to run the biggest cam possible on the street. It will be paired with a TH400. Andy advice?
I would say a 750 carb. That's what im running on my 5.7L. I just bought an 850 Demon for it which i know is over kill but it'll work fine. I would reccomend a vacuum secondary carb for your set up too. Actually i'll be selling my Holley 750 already tuned for a a 5.7 and id make a few adjsutments for your engine so it'll be pretty close to what you'll want. I rebuilt it about 200 miles ago, has new 50 cc aceltor pump, new electric choke, has adjustable metering plates now (no jets) but i'd reccomend going back to jets. Something like 74 primaries, 78 secondaries, a silver vacuum spring, it has a #34 squirter with hollow screw which should be abour right too.
Also as reccomend the 226/242 cam is a pretty good recommendation although i'd run a little more intake duration like maybe 230. The exhaust is pretty restrictive but not super restrictive. I dont think you'll be running cats or a restrictive exhaust system either so that should help the heads breath a little there too.
No not wanting to go through fly cutting and all, thanks for the recommendation. Where should I look for a cam with those specs? Oh and I will be running headers and straight through mufflers, so no restriction there.
I'm running a LS2 with L92 heads 850 db 28.8" tire about 3500lbs in a 80 Malibu wagon. My cam is a comp 595/598 232/234 112 its got a good lumpy sound, it loses a little down low but makes up for it up top. The 370s you talking about I had and changed to 410s with a 4000 stall and it woke this thing up big time. It was way to doggesh (is that a word) with those 370 gears. Look in Hot Rod mag about 2/3 months ago they did a 7 engine test in a Chevelle the stock 6.0 with 28" slicks they ran 4xx gears and a 5100 stall (I may be a little off on this) and it ran in the 11s. I also went thru the traps at 5200rpms with the 370s and this thing is good to 7200. Rod
Ok, thanks for the heads up, I might need to look into deeper gears, eventually. I read that article and thought it was very cool. How high of a stall can I go with it still being streetable?
