Cam Experts Please Help!!
These are the things I am going to do in March 2004.
1. Install ATI D-1SC supercharger kit with 7 to 8 pounds of boost.
2. 3500 TCI converter with 2.5 STR.
3. Camshaft.
4. LS1 Edit.
5. 42# Injectors.
6. Big Fuel pump.
7. 25 to 50 HP shot from my NX system.
8. Switch From my 3.73 gears back to my 3.23 Stock gears.
These are the things I will not ever do to my car.
1. No way am I going to put headers on it!
2. Remove any of my interior.
3. Remove any of my luxury items like radio, power stearing, A/C.
4. I will not modify my rearend. No Ladderbars, no 12 Bolt. Only slicks.
Here is the goal I want to acomplish and the intended use of the vehical.
1. Be able to max out at 200mph without the juice. This is an ego thing.
2. Run High 11 to low 12 second ET's in the quarter mile (I think I need the juice for this. Turn it on after 4000rpm) AT MY 3000 FOOT ELEVATION TRACK.
3. Still get 20 MPG on the interstate.
4. I drive the car 800 miles a week to work. I live in Odessa, TX and I work out of New Orleans, LA. I work offshore so I drive one way one week then the other the next.
5. Handle as good as it does now!!
So as you see, I plan to keep this car my daily driver. I want to make it a well rounded Sports car. One that is truely fast off the line. One that is truely fast on the top end. One that handles like a sports car. One that still gets great fuel milage (I think anything above 20 mpg is great). One that has all the luxury it came with. One that can destroy any stock Viper, stock Vette, stock Porch, stock Ferari, you get the picture.
Well guys, help me make it happen!
Thanks.
Scott Graham
As for changing rear ends. I will only change it after I blow the Stock one out from under it. I know it will eventually go but it will be there until then. What I was getting at as far as the rear end goes is I do not want to modify the the suspention in the rear. I still want the car to go around corners just as good as it does now.
I did not stop to think about the lack of headers will incress the tendency to detonate. That is something I will put some thought into.
And that is exactly why I asked for y'alls opinion on this. I know I can count on y'all to bring up the points I am over looking. Please keep the sugestions coming.
Thanks
Scott Graham
A 9 inch rear will not change the way your car handles on corners; mine is only 10 lbs heavier than the stock 10 bolt. NASCAR can't be wrong! As long as you don't put a locking differential in it, you will be fine. Track Lock posi in my 9 inch works great on corners.
Past the pokin a little fun.
I agree with all of y'all. I have not yet tried to work on a 2002 f-body with headers on it. I will look into the Mac Headers. If any one else has any sugestions with headers that you can still change the plugs with, please feel free to tell me.
As for the 12 bolt or 9", I am gathering you can get them to were you do not have to modify the suspention it self. So I can put one under my car and it would work just like the origanal one? Who would y'all sugest to purchase this from? How much do y'all think they cost? Which is better the 12 bolt or the 9"?
Please, don't forget the origanal question. What cams should I be looking at?
Thanks guys!
Scott Graham
Any one else?
As for the cam, get a TR224 114; this is the best street cam IMO. Anything smaller and you are just leaving power on the table for no advantages. Go bigger if you don't have emissions testing. You want a single pattern cam if you're going to have a good exhaust system with headers. Traditional splits are for the SBC or very restrictive exhaust systems. Even consider a TR230/224 if you don't need to pass emissions.
The plugs are easy to change on a GEN III engine compared to a SBC. Besides, you don't have to change them very often at all. 100,000 miles is typical.
